2486 Discussions
Parallel_sort: is it Quicksort, Mergesort, Heapsort? How about thread number?
Dave_O_
Hi
Quick question: what is the exact sorting algoirthm adopted by Parallel_sort found in TBB?
Is it:Quicksort, Mergesort, Heapsort or some combination?
How can I specify which algorithm to use by the function, as well as the number of threads to use (if possible)?
Thank you.
RafSchietekat
Valued Contributor III
Quicksort, not configurable, use separate application thread with task_scheduler_init.
(Added) Also see Parallel Stable Sort.
