2455 Discussions
Predefined macro from compiler to detect if TBB is on?
Sergey_K_Intel
Is there some definition from compiler or TBB include files to use in source code conditional compilation statements for TBB/non-TBB variants?
For example,
#if defined(TBB_<some_macro>)
... TBB-based code
#else
... non TBB-based code
#endif
This is not to add own definitions.
Sergey_K_Intel
This works only after any of TBB include files got to preprocessor.
I probably formulated my question wrong, sorry, but I wanted to determine if user turned "Intel Performance Libraries\TBB" option in IDE to "Yes", or no.
For example, how it is in general compiler, #ifdef _WIN32 use Windows source code, if not - use Linux.
I.e.
#if defined(TBB_IS_ON) // This is for example, not a real macro ))
#include <tbb/parallel_for.h>
... other TBB stuff...
#else
...use my own multi-threading...
#endif
