Below is the sample code for the Graphs Interface. I have problem building this piece of code in VS2010.
I get the following errors:
error : no instance of function template "tbb::make_edge" matches the argument list
1> argument types are: (, tbb::function_node<, int>)
1> make_edge( j, summer );
1> ^
1>main.cpp(42): error : argument list for class template "tbb::buffer_node" is missing
1> buffer_node square_buffer(g);
1>main.cpp(31): error : no instance of overloaded function "std::get" matches the argument list
1> argument types are: ()
1> my_sum += std::get<0>(v) + std::get<1>(v);
1. I have placed the contents of the Update 5 in the TBB30_INSTALL_DIR.
2. In general settings of C/C++ for the project
the Additional Include Directories is $(TBB30_INSTALL_DIR)\\include
3. In general settings of linker for the project
the Additional Library Directories are $(TBB30_INSTALL_DIR)\\lib\\ia32\\vc8 and $(TBB30_INSTALL_DIR)\\lib\\ia32\\vc_mt
4. In input settings of linker for the project
the Additional Dependencies is tbb_debug.lib
5. No paths have been mentioned in Post-Build event also.
The compiler recognizes Graph object. But not the stuffs inside the tbb namespace.
I couldn't locate where the problem is. Kindly suggest a solution.
[cpp]#define TBB_PREVIEW_GRAPH 1 #include "tbb/graph.h" #includeusing namespace tbb; using namespace std; struct square { int operator()(int v) { printf("squaring %d\n", v); return v*v; } }; struct cube { int operator()(int v) { printf("cubing %d\n", v); return v*v*v; } }; class sum { int &my_sum; public: sum( int &s ) : my_sum(s) {} int operator()( std::tuple v ) { printf("adding %d and %d to %d\n", std::get<0>(v), std::get<1>(v), my_sum); my_sum += std::get<0>(v) + std::get<1>(v); return my_sum; } }; int main() { int result = 0; graph g; broadcast_node input; function_node squarer( g, graph::unlimited, square() ); buffer_node square_buffer(g); function_node cuber( g, graph::unlimited, cube() ); buffer_node cube_buffer(g); join_node j( g ); function_node<:TUPLE> summer( g, graph::serial, sum(result) ); make_edge( input, squarer ); make_edge( input, cuber ); make_edge( squarer, square_buffer ); make_edge( square_buffer, std::get( j.inputs() ) ); make_edge( cuber, cube_buffer ); make_edge( cube_buffer, std::get( j.inputs() ) ); make_edge( j, summer ); for (int i = 1; i <= 10; ++i) input.try_put(i); g.wait_for_all(); printf("Final result is %d\n", result); return 0; }[/cpp]
Hello, Ashok,
I would like to apologize; the Forum posting software removed the template parameters from Mike's post. If you check the updated version of the forum post ( "Using the Intel Threading Building Blocks Graph Community Preview Feature: Creating a Simple Messag... ) you can see the corrected code.
Please be aware that if you copy and paste the code you might get extended-chaacters for the quotes in the printf's in square, cube and sum. (It appears we haven't tamed the Forum posting software completely yet!)
I put the code in squarer.cpp, corrected the double-quotes, and used the following Makefile:
You may have to substitute "<" for "lt;" in the Makefile; it looks like that was also substituted.
Thank you for the feedback; it is good to hear from people looking at the graph feature.
Chris
[bash]CXX = icpc OPT = -O2 ${CXXFLAGS} all: clean squarer run_tests squarer: squarer.o $(CXX) -o $@ $< $(OPT) -ltbb -ltbbmalloc squarer.o: squarer.cpp $(CXX) -c $(OPT) -o $@ $< clean: rm -f squarer *.o [/bash]
Chris
