Problems compiling with concurrent_queue
carlosrene
I've been stuck for a while trying to compile a trivial concurrent_queue, hopefully somebody could point out where I faltered.
gcc (Gentoo 4.3.2 p1.1) 4.3.2
Linux 2.6.29
tbb22_20090908oss (have also triedtbb22_004oss andtbb22_20090809oss)
g++ -g -o test-tbb test-tbb.cpp -DTBB_DO_ASSERT -MMD -DDO_ITT_NOTIFY -O0 -DUSE_PTHREAD -m64 -Wall -I../libs/tbb22/include/ -L ../libs/tbb22/lib_debug -ltbb_debug -lpthread -lrt
/* file: test-tbb.cpp */
#include
#include
using namespace std;
using namespace tbb;
int main() {
concurrent_queue queue;
queue.set_capacity(10);
for(int i=0; i < 10; ++i)
queue.push(i);
int ret;
while(!queue.empty()) {
queue.pop_if_present(ret);
cout << ret << " ";
cout << endl;
return 0;
/* this is the g++ error I get at compile-time */
test-tbb.cpp: In function int main():
test-tbb.cpp:9: error: class tbb::strict_ppl::concurrent_queue > has no member named set_capacity
test-tbb.cpp:16: error: class tbb::strict_ppl::concurrent_queue > has no member named pop_if_present
make: *** [test-tbb] Error 1
1. I don't know what namespace strict_ppl is, on the Reference Manual it says that this namespace is used when in tbb/compat.ppl.h is included.
2. I keep looking at the doxygen and the method name does exists. Could I be using the wrong version of class concurrent_queue<>?
3. The include is set correctly, since tbb only has one directory -there is no ambiguity-.
Appreciate any help, I'm sure I'm overlooking something...
Terry_W_Intel
Quoting - carlosrene
Linux 2.6.29
#include
#include
int main() {
queue.push(i);
int ret;
cout << ret << " ";
cout << endl;
return 0;
It looks like you are using TBB 2.2, but your code looks like the 2.1 API. Some small API changes were made between 2.1 and 2.2. You should double-check the latest documentation for the new use of concurrent_queue. My blog here has a quick summary of the changes.
Cheers,
Terry
Terry_W_Intel
Linux 2.6.29
#include
#include
int main() {
queue.push(i);
int ret;
cout << ret << " ";
cout << endl;
return 0;
Cheers,
Terry
