There are some problems with EnqueuedTasks in TBB v4.0. From time to time,it is not hard to
reproduce, tasks are not executed andthere is not output.
A couple of days ago Alexey Kukanov (Intel) informed everybody that there are some problems:
...that priority support for enqueued tasks is broken for now...
in a thread:
http://software.intel.com/en-us/forums/showthread.php?t=102159
Here is a Test-Case:
class CMyTask : public tbb::task
public :
CMyTask()
CMyTask( int iNumber, char *szPriorityCode )
m_iNumber = iNumber;
strcpy( m_szPriorityCode, szPriorityCode );
m_iPriority = -1;
~CMyTask()
tbb::task * execute()
printf( "[ Task Number %03ld ] [ Priority Code: %6s ] [ Priority: %10ld ]\\n",
( int )m_iNumber, &m_szPriorityCode[0], ( int )m_iPriority );
return ( tbb::task * )NULL;
void SetPriority( int iPriority )
m_iPriority = iPriority;
private:
int m_iNumber;
char m_szPriorityCode[16];
int m_iPriority;
void main( void )
printf( "Initialization started\\n" );
#if defined ( __TBB_TASK_PRIORITY )
printf( "TBB Task Priorities Enabled\\n" );
#else
printf( "TBB Task Priorities Disabled\\n" );
#endif
// Test-Case SK1
for( int i = 0; i < 3; i++ )
CMyTask &TaskL = *new( tbb::task::allocate_root() ) CMyTask( i*10+1, "low" );
TaskL.SetPriority( ( int )tbb::priority_t::priority_low );
tbb::task::enqueue( TaskL, tbb::priority_t::priority_low );
CMyTask &TaskN = *new( tbb::task::allocate_root() ) CMyTask( i*10+2, "normal" );
TaskN.SetPriority( ( int )tbb::priority_t::priority_normal );
tbb::task::enqueue( TaskN, tbb::priority_t::priority_normal );
CMyTask &TaskH = *new( tbb::task::allocate_root() ) CMyTask( i*10+3, "high" );
TaskH.SetPriority( ( int )tbb::priority_t::priority_high );
tbb::task::enqueue( TaskH, tbb::priority_t::priority_high );
printf( "Initialization completed\\n" );
about 5 seconds. Codes are not modified between runs.In a 3rd attempt tasks are not executed:
But actually that just means that they can be considered "daemon" tasks (like Java daemon threads). To instead guarantee their eventual execution, allocate them as children and wait_for_all() in their parent (verified but without use of priorities).
Perhaps this should be explicitly documented, though. And maybe it would be more convenient if enqueued root tasks weren't "daemon" tasks unless explicitly flagged so.
I suggested a way out, provided proper documentation, but to me this does not seem like an innocent little bug that can be kept from view, as it can come back to bite you in unexpected ways.
plain wrong to me. Of course if there is a real app that suffers, we will either find ways to fix it or suggest an acceptable workaround...
I've underlined some statements that caused a couple of questions:
How somebody, not just me,could use TBB in a real software whenIntel software engineer makes
statements like this?
Is that my fault that a simple test case doesn't work properly?
> That's not because I am lazy
Is it bad for anybody to admit that he is lazy, or is it only bad for an Intel engineer? :)
> but because the TBB shutdown code is so complicated already
That's just the statement of the fact. Yes, it is complicated; what's wrong with that?
Try making a DLL that creates (including lazily on first use), uses, and destroys a pool of threads, and allocates many internal resources that may or may not be re-used in the future, and may be still in use when shutdown is initiated... you will find out that this is complicated, and that startup and shutdown are very complex. You have to care about deallocating resources, avoiding deadlocks (in particular when the loader lock isinvolved), shutting down the threads correctly when the DLL is unloaded but the app continues, and etc.
> that adding more for sake of an artificial test seems plain wrong to me.
So, what's wrong with the accented part? In my opinion, the test does not represent any real application behavior, because it finishes too quickly and does not use the result of the jobs it enqueued to execute in parallel. It can be useful to investigate what are the issues with task::enqueue, but then the issues should be considered the same way as any other engineering problems,and the decision on whether it should be fixed, documented, or ignored should be done after consideration of many factors. My initial assessment is that it's not worth fixing; I did not say it's not a bug, but it seems to be a low priority issue. Perhaps I should not tell it here, or should use different words, but now it's too late. Of course I can change the opinion later, as more details are clear.
Again, what you see wrong here? Let me rephrase: if a customer comes to me with the real use case, not just a test, then the priority of the issue becomes higher, and we will find a way out suitable for the customer.
I am not a psychologist, so this question is out of my area of expertise.
No it's not your fault. Did I say that it's your fault? No I did not. Or maybe I said that the test does not deserve attention? No I did not; in fact I said that it should be investigated.
To make the discussion more constructive, do you have a real usage scenario that suffers from the problem exposed by this test, for meto raise the priority of investigating the issue?
I also agree that the issue, if not possible / too hardto fix, should be documented somewhere. It's not intentional that enqueued root* tasks behave like "daemons", but I'm afraid (again, an educated guess) that it cannot be reliably fixed. We will need to investigate it though.
*Actually, I think it's not essential that the tasks are root tasks, butit's essential that the tasks are "fired-and-forgotten", i.e. the main thread leaves without waiting for the tasks to complete.
