2455 Discussions
Question about Using Parallel Methods in a Serial Pipeline Filter
timminn
If a pipeline filterpasses trueas the serial parameterin its constructor, then the number of concurrent tokens to processed in the filter is limited to be one.
But does this serial flag has any limits if we are trying to use the parallel_for, parallel_while, or self-defined parallel task in the overrided operator() method??
Alexey-Kukanov
No it does not; pipeline is agnostic to how tokens are processed by filters, and if parallelism is possible there, it makes perfect sense to use it and increase throughput of the serial filter.
