Question on parallel_reduce
Petros_Mamales
I hope I am submirring this to the right place..
I have a simple program that calculates the sums of vectors (views to a buffer) using a single sweep.
My issue is that in two different calculations I get very different results. There is a good chance that I do something really wrong since I am relatively new to tbb.
I have two versions of the calculation: in one at join the partial sums are added on. In the second they are added to an outside buffer.
I have ran similar tasks with one target (instead of a "vector" w/out problems using similar methods (to the first). I would like the second, if it worked because it would be much more light weight per thread.
I use tbb 3 on visual studio 2010 and on windows 7.
Thank you very much in advance for the help,
Petros.
#define MAXFACTORS 100
//stl
#include
using namespace std;
//tbb
#include "tbb\\parallel_reduce.h"
#include "tbb\\blocked_range.h"
//define a vector to be a view to data:
class Vector{
public:
size_t size_;
size_t stride_;
double * data_;
Vector()
Vector(size_t size, double * const pdata, size_t stride )
:size_(size),
data_(pdata),
stride_(stride)
~Vector()
double & operator[]( const size_t i ){ return *(data_ + i* stride_ ); }
double const & operator[]( const size_t i ) const { return *(data_ + i* stride_ ); }
//define the class to be used by tbb:
class moment_calculator_local{
private:
Vector * vars_;
const size_t size_;
public:
double m1_[MAXFACTORS];
moment_calculator_local( Vector * const vars, const size_t size )
:vars_( vars ),
size_(size) {
for ( size_t i = 0; i != size_; ++i ) m1_ = 0L;
~moment_calculator_local()
const size_t size() const { return size_;}
void operator()( const tbb::blocked_range< size_t > & r ) {
const size_t nVars = size_;
size_t jVar;
for( size_t i = r.begin(); i != r.end(); ++i ) {
for ( jVar = 0; jVar != nVars; ++jVar ) {
const Vector & view_j = vars_[jVar];
const double var_j_i = view_j;
m1_[ jVar ] += var_j_i ;
moment_calculator_local( moment_calculator_local & ec, tbb::split & splt )
:vars_( ec.vars_ ),
size_(ec.size_){
memcpy( m1_, ec.m1_, ec.size_* sizeof(double)/sizeof(char) );
void join ( const moment_calculator_local & ec ) {
for ( size_t j = 0; j != nVars; ++j )
m1_ += ec.m1_;
class moment_calculator_global{
private:
Vector * vars_;
const size_t size_;
double * const tgt_;
public:
moment_calculator_global( Vector * const vars, const size_t size, double * const tgt )
:vars_( vars ),
size_(size),
tgt_(tgt) {
~moment_calculator_global()
size_t jVar;
moment_calculator_global( moment_calculator_global & ec, tbb::split & splt )
:vars_( ec.vars_ ),
size_(ec.size_),
tgt_(ec.tgt_){
void join ( const moment_calculator_global & ec ) {
tgt_ += ec.m1_;
int main(){
const size_t dimension = 5;
const size_t mcSize = 10000;
const size_t sampleSize = dimension * mcSize;
double * pdata = new double[ sampleSize ];
//create uniform random data in [0,1]
for ( size_t i = 0; i != sampleSize; ++i )
pdata = double(rand())/double(RAND_MAX) - 0.5;
//create Vectors corresponding to the columns of the sample
Vector vars[dimension];
for (size_t i = 0; i != dimension; ++i )
vars = Vector( mcSize, pdata + i, dimension );
moment_calculator_local mc( vars, dimension );
tbb::parallel_reduce( tbb::blocked_range(0, mcSize, 1000 ),
mc,
tbb::auto_partitioner() );
moment_calculator_local mc2( vars, dimension );
mc2,
cout << "Adding the results locally:" << endl;
cout << "\\t1st:\\t\\t2nd:" << endl;
cout << "\\t===:\\t\\t===:" << endl;
for ( size_t i = 0; i != dimension; ++i )
cout << i << "\\t" << mc.m1_ << "\\t\\t" << mc2.m1_ << endl;
cout << endl;
double m1Tgt[dimension]; std::fill( m1Tgt, m1Tgt + dimension, 0.L );
double m2Tgt[dimension]; std::fill( m2Tgt, m2Tgt + dimension, 0.L );
moment_calculator_global mc21( vars, dimension, m1Tgt );
mc21,
moment_calculator_global mc22( vars, dimension, m2Tgt );
mc22,
cout << "Adding the results to gloabal target buffer:" << endl;
cout << i << "\\t" << m1Tgt << "\\t\\t" << m2Tgt << endl;
return 1;
TimP
There is a forum specifically for TBB; you will likely wait longer for a TBB expert to glance at this forum.
Tools are provided for insertion of code, such as the stubby pencil tool on the toolbar, and the file attachment tool. I can't see anyone making an effort to make sense of your mangled post.
Petros_Mamales
Thank you for your reply. Tried to find the TBB forum w/out much luck I am afraid. Also tried touse the applet to upload the code snippet w/out much luck either. I guessthat was not my day ;-))
