I have a requirement where in a thread has a lot of requests( in hundreds ) to be enqueued. I was just wondering, if i can form an array or something and enqueue it directly, it should be faster than touching the shared resource again and again. But i don't find an API like that in the reference documentation. Even if i enqueue it as an array, it should get dequeued element wise.
Can someone explain what would be the best approach in solving a problem like this?
Thanks in advance,
Gokul.
- « Previous
- 1
- 2
- Next »
Intel:1,000-core Processor Possible:
http://www.pcworld.com/article/211238/intel_1000core_processor_possible.html
Sincerely,
Amine Moulay Ramdane.
Dmitry wrote:
>That's pretty cool!
>Unfortunately, I can't say the same about my code, I don't have a 100-core machine for tests...
Even if every thread or process that uses my Parallel Sort Libraryor Parallel
Compression Libraryetc. etc. will not scale beyong 16 cores , that's still fun!
You haveto *UTILIZE* your hundred or thousand cores , so run as much as possible
of your processes or threads on your systemevenif they don't scale very well !
That's still cool ...
Sincerely,
I wrote:
>Even if my lock-free ParallelQueue - that i am using inside my Object Pascal
>Thread Pool Engine - doesn't scale beyong 100 cores or 200 cores ...
>Example my a Parallel Threadthat usemy
>Parallel SortLibrary will scale to 100 cores and another thread or
>process that uses myParallel CompressionLibrary will scale to 100 cores etc. etc
But you know very well Dmitriy that it was just hypothetical example that i gave,
it was not the reality yet ...
Look for example at the follwing application,it does not scale beyong 8 or 10 cores
on a 32 cores system
http://software.intel.com/en-us/blogs/2010/11/18/benchmarks-of-a-haskell-model-checking-application-running-on-intels-manycore-testing-lab-2/
But as i said before, even if every thread or process that uses my
Parallel Sort Libraryor Parallel Compression Libraryetc. etc. will not scale
of your processes or threads on your future 100 or 1000 cores systemevenif they
It's good to make it scale 'better', but, in reality, a much perfect scale isharderto realize...
Sincerely,
Yeah, I saw this one. The funny thing is that the type of simulation they do should easily scale to 32 cores.
The problem is not sub-linear scalability, the real problem is negative scalability. Check out graphs in the article you pointed to, what number of threads would you choose for the program - 32 or 16?
Dmitry:
>Check out graphs in the >article you pointed to, what number of threads would you
You are right...
And they didn't say in the webpagewhat wasis factor that limit and even make a negative scalability?
have you any idea on this simulation program Dmitiry ?
Sincerely,
Amine.
There are a lot of possible problems. I don't know how they parallelize it, and don't know details of Haskell scheduler and runtime, so I have no idea wrt negative scalability.
I understand.
They have not talked about it , and have notexplain to us what
was happening exactly inside there code...
Sincerely,
Amine.
>> In the lock-free Array based queue there is *NO* CONTENTION on the locks
>> insidea freelist ora memory manager.
Can you point me to some article on this? So does that mean, it wouldn't matter if i do the batch inserts as multiple single inserts?
Gokul.
- « Previous
- 1
- 2
- Next »
