Reduce on hashmaps
Sensei_S_
Dear all,
I am now trying to use a parallel_reduce on a concurrent_hash_map, always with lambdas. My hashmap is very basic, maps strings to integers, however, I am not able to compile:
    // Handy
    typedef tbb::concurrent_hash_map<std::string, std::size_t> hashtype;
    typedef tbb::blocked_range<hashtype::iterator> rangetype;
    hashtype tmp;
    typename hashtype::accessor accessor;
    std::string k;
    k = "AAAA";
    tmp.insert(accessor, k);
    accessor->second = 10;
    k = "BBBB";
    accessor->second = 4;
    k = "ABCD";
    accessor->second = 7;
    // Compute the sum
    auto sum = tbb::parallel_reduce(rangetype(tmp.begin(), tmp.end()),
                                    0,
                                    [](rangetype &r, std::size_t init) -> std::size_t
                                        std::size_t q = init;
                                        for (auto &p : r)
                                            q += p.second;
                                        return q;
// THE FOLLOWING WASN'T THE PROBLEM, I THINK
//                                        return std::accumulate(r.begin(), r.end(), init,
//                                                               [&r, &init](const hashtype::value_type &p) -> std::size_t
//        return init + p.second;
                                    std::plus<std::size_t>());
The errors regard some problems with the empty() function, so I am doing something wrong here (obviously!).
/usr/local/include/tbb/blocked_range.h:82:42: error: invalid operands to binary expression ('const tbb::interface5::internal::hash_map_iterator<tbb::interface5::concurrent_hash_map<std::__1::basic_string<char>, unsigned long, tbb::tbb_hash_compare<std::__1::basic_string<char> >, tbb::tbb_allocator<std::__1::pair<std::__1::basic_string<char>, unsigned long> > >, std::__1::pair<const std::__1::basic_string<char>, unsigned long> >' and 'const tbb::interface5::internal::hash_map_iterator<tbb::interface5::concurrent_hash_map<std::__1::basic_string<char>, unsigned long, tbb::tbb_hash_compare<std::__1::basic_string<char> >, tbb::tbb_allocator<std::__1::pair<std::__1::basic_string<char>, unsigned long> > >, std::__1::pair<const std::__1::basic_string<char>, unsigned long> >')
    bool empty() const {return !(my_begin<my_end);}
As you can see, I've also tried to remove the call to std::accumulate, trying to exclude that as the culprit. I believe I can say that it isn't really the problem here.
Can you help me?
Thanks!
Vladimir_P_1234567890
concurrent_hash_map has own ranges implementation.
change lines 24-27 to
    // Compute the sum
    auto sum = tbb::parallel_reduce(tmp.range(),
        0,
        [] (hashtype::range_type &r, std::size_t init) -> std::size_t
More details https://www.threadingbuildingblocks.org/docs/help/hh_goto.htm#reference/containers_overview/concurrent_hash_map_cls/parallel_iteration_container.htm
--Vladimir
I think that blocked_range uses operator<() which is not implemented for concurrent_hash_map.
--Vladimir
    // Compute the sum
        0,
--Vladimir
Sensei_S_
Thanks Vladimir, I think I'm still not there though...
    // Handy range type
    typedef tbb::blocked_range<hashtypeZ::iterator> rangetype;
    hashtype tmp;
    std::string k;
    k = "AAAA";
    k = "BBBB";
    k = "ABCD";
    // Serial code
    std::size_t sum = std::accumulate(tmp.begin(), tmp.end(), 0,
                                      [](std::size_t s, const hashtype::value_type &p)
                                          return s + p.second;
    // Compute the sum of all frequencies
                                    0,
                                        for (const auto &p : r)
                                            q += p.second;
                                        return q;
But now I'm getting another error:
/usr/local/include/tbb/parallel_reduce.h:322:24: error: no matching function for call to object of type 'const (lambda at /Users/sensei/Documents/Projects/sequence/sequence/sequence/assembler/lmf_graph.cpp:70:37)'
            my_value = my_real_body(range, const_cast<const Value&>(my_value));
/usr/local/include/tbb/parallel_reduce.h:151:37: note: in instantiation of member function 'tbb::internal::lambda_reduce_body<tbb::interface5::internal::hash_map_range<tbb::interface5::internal::hash_map_iterator<tbb::interface5::concurrent_hash_map<std::__1::basic_string<char>, unsigned long, tbb::tbb_hash_compare<std::__1::basic_string<char> >, tbb::tbb_allocator<std::__1::pair<std::__1::basic_string<char>, unsigned long> > >, std::__1::pair<const std::__1::basic_string<char>, unsigned long> > >, int, (lambda at /Users/sensei/Documents/Projects/sequence/sequence/sequence/assembler/lmf_graph.cpp:70:37), std::__1::plus<unsigned long> >::operator()' requested here
        void run_body( Range &r ) { (*my_body)( r ); }
I've tried using [](const rangetype &r, std::size_t init) -> std::size_t, but it didn't help.
Thanks!
you have not changed rangetype to hashtype::range_type on line 34. I've asked to copy 4 lines:)
--Vladimir
Sensei_S_
Aw man, I thought I copied that! My bad, sorry!
Thanks, it works wonderfully! ;)
