Release linker error LNK2001
fanaticlatic
hi folks,
I am getting the following error only when building as release, when building for debug the program runs fine:
error LNK2001: unresolved external symbol @__TBB_machine_trylockbyte@4
Any help or ideas how i can solve this would be appreciated,
Cheers,
Mark.
fanaticlatic
Fixed!
The problem for anyone with a similar issue in the future was that I had set the calling convention to __fastcall rather than __ccall. Seems a bit awkward if one function forces you to the __ccall convention. Any way around it or a reason for it anyone know?
Anton_Pegushin
New Contributor II
Quoting - fanaticlatic
Fixed!
Hello, this problem has been fixed in the library starting with "20080825" open-source developers' build and TBB 2.1 Update 1 commercial-aligned build. If you update your version of TBB, you'll be able to compile your product with __fastcall as a default calling convention.
