Repository change on Github
Ries__Uilian
Hi!
I would like to know why the Github repository has been changed from https://github.com/intel/tbb to https://github.com/oneapi-src/oneTBB.
Also, the check for v2020.0 does not match between the new URL and the old one. If it's a source code snapshot and follow the same tag, why does is it different?
https://github.com/intel/tbb/archive/v2020.0.tar.gz SHA-256 8eed2377ac62e6ac10af5a8303ce861e4525ffe491a061b48e8fe094fc741ce9
https://github.com/oneapi-src/oneTBB/archive/v2020.0.tar.gz SHA-256 57714f2d2cf33935db33cee93af57eb3ecd5a7bef40c1fb7ca4a41d79684b118
Ries__Uilian
From Github:
After unpacking these packages this looks like so now:
oneTBB-2019_U9 oneTBB-2020 oneTBB-2020_U1
This means that the middle version the oneTBB-2020 no longer has a '.0' version.
Thus,  not only the repository has been changed, but also the TBB version. Is there any reason for this?
James_T_Intel
I apologize for this not being addressed sooner. The changes between TBB and oneTBB are around a TBB revamp. Please see https://software.intel.com/content/www/us/en/develop/articles/tbb-revamp.html for details on the changes. The old repository was migrated to the new repository in order to maintain consistency between all parts of the Intel oneAPI implementation and to avoid having two separate TBB repositories.
