Request For NullMutex Feature
ksgokul
Lot of times, when we do template meta programming, we need to provide some containers with no mutex( tbb containers ) and some containers with a tbb Mutex (Boost /std containers). The Scoped Lock feature makes the code different for both. If we can have a NullMutex feature like the one available in ACE( ACE_Null_Mutex), it would be easy to handle such situations. Please advise me on any work arounds currently available.This NullMutex is more like a no-op.
Thanks in advance,
Gokul.
Alexey-Kukanov
If you only use scoped lock pattern (i.e. no explicit calls to acquire/release), the following should work:
[cpp]class null_mutex {
    //! Deny assignment and copy construction
null_mutex( const null_mutex& ); void operator=( const null_mutex& ); public: class scoped_lock { public: scoped_lock( null_mutex& ) {} ~scoped_lock() { } }; // Mutex traits static const bool is_rw_mutex = false; static const bool is_recursive_mutex = false; static const bool is_fair_mutex = false; }; [/cpp]
Anyway the idea is reasonable. Thanks for the suggestion.
Alexey-Kukanov
ksgokul
public:
class scoped_lock {
public:
~scoped_lock() { }
// Mutex traits
[/cpp]
Thanks for the Solution..
Gokul.
Alexey-Kukanov
We willmake an extended version of it part of TBB.
Also during the internal discussion, it was suggested that is_recursive and is_fair traits should be true for null_mutex.
ksgokul
Great to hear that the request has been accepted. I will update the static variables accordingly. Actually the new values make a lot of sense.
