2455 Discussions
[SOLVED] An issue with 'tbb::tick_count' class
SergeyKostrov
Valued Contributor II
I detected an issue with 'tbb::tick_count' class. Please take a look at a test-case:
tbb::tick_count starttick;
tbb::tick_count endtick;
starttick = tbb::tick_count::now();
::Sleep( 5000 ); // 5000 ms = 5 seconds
endtick = tbb::tick_count::now();
_tprintf( _T("Task Delay: %ld secs\\n"), ( int )( endtick - starttick ).seconds() );
A delay is 5 seconds. However, '( endtick - starttick ).seconds()' returns 4 seconds. It is reproducible
with a test application compiled in Debug and Release configurations and TBBs v4 updates 3 and 1.
A generic description of the problem is as follows:
If a delay of N seconds is expected then '( endtick - starttick ).seconds()' always returns N-1 seconds.
My Development Environment:
OS : Windows XP 32-bit SP3
IDE: Visual Studio 2005 SP1
TBB: Version 4 Update 3
TBB: Version 4 Update 1
RafSchietekat
Black Belt
What do you get without casting to an integral type (which discards the entire fractional part)? And how would you be able to tell that it isn't Sleep() that's returnng a fraction too early? Have you compared with other timng API, or inspected the source code?
Vladimir_P_1234567890
hello, what is a result in ms? ::Sleep() can return eariler than its arg. If result is 4999ms expect that result in seconds is '4'.
--Vladimir
SergeyKostrov
--Vladimir
I would expect an opposite due to amultitaskingin Windows OS.So,a real interval could be more than 5000ms.
SergeyKostrov
Thanks for these tips andI'll take a look tomorrow.
Sergey
SergeyKostrov
[SOLVED]. A 'seconds()' method returns aresult as a double-precisionfloating-pointvalue ( type 'double' ).
A modified test-case:
::Sleep( 2000 );
_tpintf( _T("Task Delay: %f secs\n"), ( endtick - starttick ).seconds() );
_tpintf( _T("Task Delay: %1.f secs\n"), ( endtick - starttick ).seconds() );
outputs correct results:
Task Delay: 1.988046 secs
Task Delay: 2 secs // Rounded by '_tprintf' to 1 digit
