Simple question that I cant seem to find the answeer to: is a processor that supports SSE2 a requirement to use intel threading building blocks?
I am using another computer to test some network code that I wrote to run on a mutlicore processor. So I need two computers to test the network code(not really, I know I can use 127.0.0.1, thats besides the point). The other computer only supports the SSE intruction set and I cannt seem to be able to compile an exe that does not use the mfence instruction, which causes errors on the other computer. Am I SOL on this?
Also, another question that I know I read the answer to a long time ago, but I forget exactly what the answer was. What is the deal with tbb using 100% of the cores? Does it really hog all the cores so that other applications get a very very small slice of them? Or is what I am seeing just some kind of illusion and the cores are not really being used so heavy?
Hello, right about mfence.
Hardware - Supported
Intel Pentium 4 processor family and higher
Intel Itanium processor family (Linux* systems only)
Non Intel processors compatible with the above processors
To workaround this you can look at the thread.
--Vladimir
