2487 Discussions
Sample code for PROG_LED#, WDTO# of Intel NUC D34010WYB
Anant_A_
As mentioned in the technical documentation of D34010wyb, Intel can provide sample code for programming the GPIOs PROG_LED# and WDTO# of the custom header solution.
Where can I get the codes. I need the code for both Windows and Linux(Ubuntu).
Vladimir_P_1234567890
it looks you have reached the wrong forum. this forum is about Intel® Threading Building Blocks
--Vladimir
