I am currently using a TBB flow graph in which a) a parallel filter processes an array (in parallel with offsets) and puts processed results into an intermediate vector (allocated on the heap; mostly the vector will grow up to 8MB). These vectors are then passed to nodes which then postprocess these results based on their characteristics (determined in a)). Because of synchronized resources, there can only be one such node for each characteristic. The prototype we wrote works well on UMA architectures (tested on a single CPU Ivy Bridge and Sandy Bridge architecture). However, the application does not scale on our NUMA architecture (4 CPU Nehalem-EX). We pinned the problem down to memory allocation and created a minimal example in which we have a parallel pipeline that just allocates memory from the heap (via malloc of a 8MB chunk, then memset the 8MB region; similar to what the initial prototype would do) up to a certain amout of memory. Our findings are:
- On a UMA architecture the application scales up linearly with the number of threads used by the pipeline (set via task_scheduler_init)
- On the NUMA architecture when we pin the application to one socket (using numactl) we see the same linear scale-up
- On the NUMA architecutre when we use more than one socket, the time our application runs increases with the number of sockets (negative linear scale-"up")
For us this smells like heap contention. What we tried so far is to substitute Intel"s TBB scalable allocator for the glibc allocator. However, the initial performance on a single socket is worse than using glibc, on multiple sockets performance is not getting worse but also not getting any better. We gained the same effect using tcmalloc and the hoard allocator.
My question is if someone experienced similar issues. Stack-allocation is not an option for us as we want to keep the heap-allocated vectors even after the pipeline ran.
Update: I attached perf stats for the various executions with numactl. Interleaving/localalloc has no effect whatsoever (the QPI bus is not the bottleneck; we verified that with PCM, QPI link load is at 1%).
Update 2: I also added a chart depicting the results for glibc, tbbmalloc, and tcmalloc.
- « Previous
- 1
- 2
- Next »
- « Previous
- 1
- 2
- Next »
