Is it possible within tbb to schedule a task to run at a specific time, and/or potentially to tun every x seconds?
I'm ideally looking for this to trigger a tbb_pipeline to run.
If not, how might this be accomplished?
Quoting - derbai
I would ideally like to do processing at various times of the day.
One example of this would be to an ftp site every hour, download files, parse files etc etc
Qt and ACE offer this functionality within their schedulers, and I was hoping Tbb would do something similar.
while(WaitOneHourOrTerminate())
// create TBB working set
// distroy TBB working set
Quoting - derbai
No there is no way to control behavior of TBB tasks like you described.
What exactly do you try to achieve? I.e. why starting pipelines run at specified times?
Quoting - Alexey Kukanov (Intel)
I guess one approach could be to create a standard thread using the tbb::tbb_thread class. You could have it wake up on whatever your schedule is and kick off a bunch of tasks or a pipeline.
Peter
Quoting - derbai
No TBB does not have such a functionality, sorry. TBB is not a general-purpose framework but a computational parallelism oriented library. I guess you might be able to combine it with general purpose frameworks though, using it at levels when you would benefit from parallel computation on multicore systems.
Quoting - pvonkaenel
Peter
I second this approach, it's easy and does the job without adding dependencies.
Quoting - derbai
