Hi! I'm getting segmentation fault when using fgt2xml (or fgt2xml_debug). `0x000055555564220f in fgt_record_processor::dump_trace (this=0x7fffffffd7e0) at /localdisk/jenkins/workspace/FGA_Linux_build/fgatool/src/collector/src/fgt2xml/fgt_record_processor.cpp:1089`. Is there any chance to open source this tool? Otherwise I have no idea how to find out the root cause of the issue.
Could you please provide us your system environment details(OS version)?
Could you also provide us the version of Intel one API you have been using and complete error log?
Thanks & Regards
Shivani
As we didn't hear back from you, Is your issue resolved? If not, please provide the details that have been asked in my previous post.
Thanks & Regards
Shivani
Could you please provide us the complete error log to investigate more on your issue?
Thanks & Regards
Shivani
We are working on it and will get back to you soon.
Thanks & Regards
Shivani
I have an idea now of what is going on. TBB_USE_PROFILING_TOOLS was enabled on tbb::flow code only and not in other files files that use tbb. After enabling TBB_USE_PROFILING_TOOLS globally, I was able to get valid fgt2xml output. Anyway, segmentation fault must be fixed.
Thanks for providing the zip file of the FGT traces and triaging the possible reason as to why this might be happening. This will help us find a fix when only partial set of files are compiled with TBB_USE_PROFILING_TOOLS.
--Vasanth
