Segmentation fault with OpenMP
Riyad_Parvez
I'm using Intel TBB concurrent_hash_map and concurrent_vector with OpenMP for loop parallelization. I've used tbb::task_scheduler_init. But I'm getting segemntation fault. Interesting matter is when I open the terminal and run for first time the code in that terminal, it works perfectly. But after first run in terminal, if I run that code again in same terminal without closing it gives segmentation fault. How can I debug that?
Riyad_Parvez
After checking in Valgrind, I've found the problem. I was trying to sort concurrent_vector by using std::sort. Can I use std::sort to sort concurrent_vector? Otherwise how can I do it?
Vladimir_P_1234567890
I guess you can try to use tbb::parallel_sort.
RafSchietekat
Valued Contributor III
Neither sort nor parallel_sort is allowed while the container is also being accessed by other threads. If it is not, both should work.
