Reading the predefined node types here , I can may the concept of a source node to the input_node type.
For a sink node (only input, no output), which predefined node type is suitable for use ?
Cheers
You can use function_node() to create a sink node without creating furthur edges from function_node() to any other node.
Please refer to below link for more details:
https://spec.oneapi.io/versions/1.1-rev-1/elements/oneTBB/source/flow_graph/func_node_cls.html
Thanks & Regards,
Noorjahan.
Thanks & Regards,
Noorjahan.
We haven't heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Noorjahan.
Thanks for accepting our solution.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Noorjahan.
