Small Documentation Error
superfunc
In the documentation for parallel_reduce (https://www.threadingbuildingblocks.org/docs/help/reference/algorithms/parallel_reduce_func.htm). There is a typo in the Functor based implementation signature. Body is a non-const reference, as it will be internally modified with the final result of the reduction.
template<typename Range, typename Body>
void parallel_reduce( const Range& range, const Body& body
                      [, partitioner[, task_group_context& group]] );
should be
void parallel_reduce( const Range& range, Body& body
RafSchietekat
Black Belt
Good catch, but a bit more than a "typo".
