Are old AMD CPUs without mfence supported by TBB 4.0? I gather they weren't with v2.2. According to the forum, there is a workaround that involves recompiling using a different instruction. I am hoping that by now the workaround as been incorporated into the main product. All the discussion I've found about this was a couple of years old. The documentation does not have anything relevant under "known issues", nor can I see
If not, does anyone know if Microsoft's PPL has the same limitation?
[SergeyK] It looks like no. Take a look at:
windows_ia32.h
#define __TBB_full_memory_fence() __asm { __asm mfence }
As you can see there are no any CPU-related macros around __TBB_full_memory_fence for 32-bit Windowsplatforms.
Take a look atwindows_intel64.h. In thatcasefor64-bit Windows platforms__TBB_full_memory_fence depends on
a C++ compiler, that is, Intel or Microsoft.
Sergey
As a workaround, reimplement __TBB_full_memory_fence in include/tbb/machine/windows_ia??.h to, e.g., do a compare-and-swap on a global dummy variable (no loop, just a single call), or anything your compiler provides that will do the trick (built-in, new C++ standard, ...).
It gets confusing... Take a look at adiscussion:
https://blogs.oracle.com/dave/entry/instruction_selection_for_volatile_fences
...There are still platforms where MFENCE is clear winner (older AMD processors, for instance)...
I think a question to AMD could clear it.
Feel free to amend my suggestion to use a local variable instead (and/or a different RMW instruction).
- Intel Pentium 4 processor family and higher
- Non Intel processors compatible with the above processors
I've contacted AMD and this is their response:
We at Global Customer Care would not be suited to answer these questions. I suggest that you visit our developer
forums and register there and post these questions you have. The correct people within the forums will give you
the best proper answer.
Thanks for the reply. Although it's not what I wanted to hear, as my employer does need to support customers with old hardware.
Could you follow a link:
http://developer.amd.com/pages/default.aspx
fromaPost #10? Your problem is related to AMD CPUs andI thinkAMD engineers could answerall your questions.
Another alternative, specific to Windows, seems to be MemoryBarrier(). (Hopefully "It may also prevent the compiler from re-ordering read and write operations.", my emphasis, is just bad technical writing.)
