Support for Clang on Linux
rwhadsell
We have been using TBB on Linux with g++ for a few years.  Now we would like to try to use TBB with Clang.  Does anyone have a version of build/linux.clang.inc that I could use?
Are there plans to release support for Clang?
FYI: I downloaded the latest stable release of TBB (4.1 Update 1), and I have Clang 3.3 (fairly recent svn version) built with g++ 4.7.1 on Fedora 14.
rwhadsell
This is the error that ends the build (with my attempt to merge linux.gcc.inc and macos.clang.inc into linux.clang.inc): ../../build/Makefile.tbb:39: CONFIG: cfg=debug arch=intel64 compiler=clang os=linux runtime=cc4.5.1_libc2.12.90_kernel2.6.35.14 /netDISKS/master/netmt/LINUX_INTF14/rnd/clang/3.3.0/bin/clang++ -gcc-toolchain /opt/gcc-4.7.1 -c -MMD -DTBB_USE_DEBUG -DDO_ITT_NOTIFY -g -O0 -DUSE_PTHREAD -m64 -fPIC -D__TBB_BUILD=1 -Wall -Wno-parentheses -Wno-non-virtual-dtor -Wno-unused-value -I../../src -I../../src/rml/include -I../../include ../../src/tbb/itt_notify.cpp In file included from ../../src/tbb/itt_notify.cpp:55: In file included from ../../src/tbb/tools_api/ittnotify_static.c:29: ../../src/tbb/tools_api/ittnotify_config.h:267:33: error: unsupported inline asm: input with type 'long' matching output with type 'int' : "0"(addend), "m"(*(long*)ptr) ^~~~~~ In file included from ../../src/tbb/itt_notify.cpp:55: ../../src/tbb/tools_api/ittnotify_static.c:534:13: warning: explicitly assigning a variable of type 'int' to itself [-Wself-assign] namelen = namelen; ~~~~~~~ ^ ~~~~~~~
Anton_P_Intel
you can temporary comment _all_ following lines in the result (from merge) makefile : ITT_NOTIFY = -DDO_ITT_NOTIFY
rwhadsell
Thanks. That got past the asm error. I thought I had another problem, but I now see what I did wrong in my linux.clang.inc. I'm retracting what I posted a few minutes ago.
