Support for actor programming model
Mukesh_B_Intel
I was wondering if we can implement the actor programming model using TBB.
Thanks in advance
Mukesh
Dmitry_Vyukov
Valued Contributor I
It depends on what do you mean by "using TBB" and on functional and performance requirements on actor model implementation.
It simplest way is to create thread (tbb::tbb_thread) per agent and use tbb::concurrent_queue for message passing.
robert_jay_gould
Quoting - Dmitriy Vyukov
I remember trying this but it wasn't too good, then I switched the queues to a front buffer and back buffer vectors (just as with swapping video buffers), the actor would process one buffer, while the other was being filled with new tasks, once the actor finished its current buffer it did a swap to the other buffer, this way I greatly reduced locking and increased locality and concurrency, it worked fine. I had a few thousand (I think 10000) actors running in near realtime, but this was just an experiment I did about a year ago, didn't have time to continue this approach but it worked decently. So if someone has the time to invest in this approach it seemed reasonably viable.
robert_jay_gould
Just remembered, I didn't use one thread per actor I had a container of actors, and a 2x threads (2 per processor), they would iterate through the groups of actors updating them in batches. This way I reduced the context switching, and thread overhead in general to support the thousands of actors scenario.
Dmitry_Vyukov
No, it's not not too good, it depends on requirements :)
Your approach is (1) definitely harder and longer to implement, (2) strictly speaking is not based on TBB and requires manual creation of synchronization primitives, (3) prohibits blocking in actor callbacks.
Mukesh_B_Intel
Both Actually
1) Using TBB (which you have answered)
2) Improving TBB to provide better support for this model.
robert_jay_gould
I had forgotten what the problem was with my experiment back then, and why I dropped it, but you got it:
"(3) prohibits blocking in actor callbacks."
This was the stumbling stone of my implementation. So yes anyone trying to do this has to be careful of this point in particular
RafSchietekat
Valued Contributor III
Actors getting callbacks... we're still talking computers, are we?
How big a problem are blocking callbacks in actual practice? Is it perhaps too difficult to use continuations instead? Is anything being done with cluster detection to improve locality?
Dmitry_Vyukov
Quoting - Raf Schietekat
If you want to access Oracle or PostgreSQL, it is quite difficult to use continuations.
In order to force user to use only continuations, you have to provide async wrappers for anything - network IO, disk IO, COM port IO, every database IO, etc.
RafSchietekat
Well... I still don't like the idea of having so many threads (stack space, locality). I would prefer a solution that operates a minimal number of preferably mutually exclusive software threads per hardware thread (maybe user threads?), and then it would be nice to have actors migrate to have the set served almost in batch by each hardware thread correlate well with any communication clustering, corrected for fairness. So my answer to the original question would be: er, no? But maybe I should stick to atomics for now. :-)
Dmitry_Vyukov
There is well-know algorithm for this, called something like "IBM freelist with reversing". Cost per enqueue operation is single CAS, and consumer executes single XCHG operation per *batch* of nodes. Consumer is totally wait-free, producers are lock-free wrt each other. Sounds nice...
[cpp]// multi-producer/single-consumer causal-fifo queue
struct agent_queue
    struct node
        node*       next;
        void*       data;
    atomic   tail;
    char            pad [cache_line_size];
    node*           head;
    void enqueue(node* n)
        n->next = tail.load(relaxed);
        while (!tail.compare_exchange(n->next, n, release));
    node* dequeue()
        if (head)
            node* n = head;
            head = n->next;
            return n;
        if (tail.load(relaxed) == 0)
            return 0;
        node* n = tail.exchange(0, acquire);
        node* prev = 0;
        for (;;)
            node* next = n->next;
            if (next == 0)
                break;
            n->next = prev;
            prev = n;
            n = next;
        head = n->next;
        return n;
[/cpp]
Dmitry_Vyukov
... however it can be further improved. I've designed fifo queue especially for actor/agent oriented libraries. First of all, it removes nasty "reversing" operation (which seems not very cache friendly), second producers are wait-free wrt each other, third consumer executes XCHG even rarer. The only unpleasant thing is that producers potentially can block consumer, but probability of this is extremely small and agent oriented run-time can tolerate this just by switching to another agent.
Here is basic algorithm:
[cpp]struct mpscq_t
    mpscq_node_t* volatile  head;
    mpscq_node_t*           tail;
    mpscq_node_t            stub;
#define MPSCQ_STATIC_INIT(self) {&self.stub, &self.stub, {0}}
void mpscq_create(mpscq_t* self)
    self->head = &self->stub;
    self->tail = &self->stub;
    self->stub.next = 0;
void mpscq_push(mpscq_t* self, mpscq_node_t* n)
    n->next = 0;
    mpscq_node_t* prev = XCHG(&self->head, n);
    prev->next = n;
mpscq_node_t* mpscq_pop(mpscq_t* self)
    mpscq_node_t* tail = self->tail;
    mpscq_node_t* next = tail->next;
    if (tail == &self->stub)
        if (0 == next)
            return 0;
        self->tail = next;
        tail = next;
        next = next->next;
    if (next)
        self->tail = next;
        return tail;
    mpscq_node_t* head = self->head;
    if (tail != head)
        return 0;
    mpscq_push(self, &self->stub);
    next = tail->next;
    if (next)
        self->tail = next;
        return tail;
    return 0;
} [/cpp]
You can find more details here:
http://groups.google.com/group/lock-free/browse_frm/thread/55df71b87acb8201
and here:
http://groups.google.com/group/lock-free/browse_frm/thread/8b4784dbe03b7880
robert_jay_gould
Indeed it looks like s a good implementation as far as I can see, if I get around to reviving my actors experiment I might give it a try. My implementation also allowed producers to block consumers, but since the blocking is so short and unlikely I had no problems with it in practice.
However I had the issue with blocking operations in my original design which sent everything to the freezer until I have time to revisit it.
Anyways as mentioned the asynchronous solution to blocking (using a database or other blocking system) is to have a message sent to save X, and get a callback to the actor message queue.Problem with this approach is the Actors become too dependent on these other systems (breaking encapsulation orresponsibilities), and forcing the user to think too much about theasynchronousityof the system (breaking the point of a nice API).
One off the bat solution I had but didn't implement yet, was to keep a normal thread pool, and another pool for blocking actions. Then the Actor's methods/message handlers would be functors that specify their policy as either blocking or not. This way the runtime could choose which actor tasks to run on which pool, thus giving a bit more intelligence to the system
[cpp]Actor robert = ActorFactory();
robert.attach(new handler(callbackA));
robert.attach(new handler(callbackB));[/cpp]
The advantage would be something like this would allow the user to use Lambda's in place of the callbacks, and message sorting, and callback tables would be done through templatespecialization.
Anyways as I said, I didn't actually try this other approach, but it seemed like a decent idea.
