New update is available on our open source site.
TBB 2.2 Update 3 commercial-aligned release
Changes (w.r.t. TBB 2.2 Update 2 commercial-aligned release):
- PDF documentation updated.
Bugs fixed:
- concurrent_hash_map compatibility issue exposed on Linux in case
two versions of the container were used by different modules.
- enforce 16 byte stack alignment for consistence with GCC; required
to work correctly with 128-bit variables processed by SSE.
- construct() methods of allocator classes now use global operator new.
--Vladimir
It seems that updated PDFs weren't uploaded yet. The last revision date of the reference manual is 2009-Jul-3.
Thanks. I've uploadednew PDFs totheopen sourcesite, 'Open Source Documentation' section.
--Vladimir
Topic Options
