2486 Discussions
TBB 3.0 update 3 commercial-aligned release is available
Vladimir_P_1234567890
TBB 3.0 update 3 commercial-aligned release is available on our open source site.
TBB 3.0 Update 3 commercial-aligned release
Changes (w.r.t. TBB 3.0 Update 2 commercial-aligned release):
- cache_aligned_allocator class reworked to use scalable_aligned_malloc.
- Improved performance of count() and equal_range() methods
in concurrent_unordered_map.
- Improved implementation of 64-bit atomic loads and stores on 32-bit
platforms, including compilation with VC 7.1.
- Added implementation of atomic operations on top of OSAtomic API
provided by Mac OS* X.
- Fixed a data race in task scheduler destruction that on rare occasion
could result in memory corruption.
- Removed gratuitous try/catch blocks surrounding thread function calls
in tbb_thread.
- Xcode* projects were added for sudoku and game_of_life examples.
- Xcode* projects were updated to work without TBB framework.
Open-source contributions integrated:
- MinGW-64 basic support by brsomoza (partially).
- Patch for atomic.h by Andrey Semashev.
- Support for AIX & GCC on PowerPC by Giannis Papadopoulos.
- Various improvements by Raf Schietekat.
Dmitry_Vyukov
Valued Contributor I
What exactly does it mean? TIA
Dmitry_Vyukov
Hummm... here is code from tbb30_035:
[bash].code
	ALIGN 4
	PUBLIC c __TBB_machine_load8
__TBB_machine_Load8:
	; If location is on stack, compiler may have failed to align it correctly, so we do dynamic check.
	mov ecx,4[esp]
	test ecx,7
	jne load_slow
	; Load within a cache line
	sub esp,12
	fild qword ptr [ecx]
	fistp qword ptr [esp]
	mov eax,[esp]
	mov edx,4[esp]
	add esp,12
	ret
load_slow:
	; Load is misaligned. Use cmpxchg8b.
	push ebx
	push edi
	mov edi,ecx
	xor eax,eax
	xor ebx,ebx
	xor ecx,ecx
	xor edx,edx
	lock cmpxchg8b qword ptr [edi]
	pop edi
	pop ebx
	ret
EXTRN __TBB_machine_store8_slow:PROC
.code
	ALIGN 4
	PUBLIC c __TBB_machine_store8
__TBB_machine_Store8:
	mov ecx,4[esp]
	test ecx,7
	jne __TBB_machine_store8_slow ;; tail call to tbb_misc.cpp
	fild qword ptr 8[esp]
	fistp qword ptr [ecx]
	ret
end
[/bash]
And here is code from tbb30_104:
[bash].code
	ALIGN 4
	mov ecx,4[esp]
	test ecx,7
	jne load_slow
	sub esp,12
	mov eax,[esp]
	mov edx,4[esp]
	add esp,12
	ret
load_slow:
	push ebx
	push edi
	mov edi,ecx
	xor eax,eax
	xor ebx,ebx
	xor ecx,ecx
	xor edx,edx
	pop edi
	pop ebx
	ret
.code
	ALIGN 4
	mov ecx,4[esp]
	test ecx,7
	ret
end
[/bash]
They are bitwise equal... what I'm missing?
RafSchietekat
Valued Contributor III
"What exactly does it mean?"
This seems be about the replacement of tbb30_056oss/include/tbb/atomic.h:278-305 with a more general arrangement that doesn't have to reflect all possible atomic specialisations.
yboucher81
We distribute the commercial version of TBB as part of a plugin for Internet Explorer and Firefox. But under Windows XP SP3, the MSVCR90.dll is not present by default, and tbb.dll has a dependency on it. So we thought that we could download the source code and build the TBB library ourselves using the configuration that links statically with the C runtime. This works, but the problem is that the resulting dlls (tbb and tbbmalloc) are not signed by Intel Corporation.
Could Intel provide the two versions of the TBB libraries (linked statically or dynamically with the C runtime), and sign the resulting dlls, so that we don't have to distribute the MSVCR90.dll with our plugin?
Thank you
pvonkaenel
New Contributor III
They do. In the lib directory you should have a sub-directory labeled vc_mt - this version is statically linked against the MS run-time.
Peter
yboucher81
Unhappily, this is not the case.
We got the vc_mt folder in both bin/ia32 and bin/intel64 folders, for the commercial version 3.0.
But these folders do not exist in the v3.0 update 3.0 that was just released.
May be this is simply a mistake.
Could Intel provide these libraries, please, for the update 3?
They are available in the comm install via registration center download, aren't they?
open source version does not contain precompiled vc_mt binaries. They need to be built from sources.
--Vladimir
yboucher81
Thank you for your answer.
Yes they are available in the commercial version, but not in the Update 3.
Does it mean that we can't have vc_mt signed dlls by Intel for the Updates that Intel releases?
That would be really unfortunate. We would like to use the stable updates when they available.
The other alternative, is to build our plugin and link it statically against the TBB lib files. This way, we won't need to have the dlls signed by Intel. But this is not our first preference.
Please confirm...
Yves
Quoting yboucher81
hi Yves,
did you usew_tbb_3.0.3.104.exe file to install the update?
--Vladimir
yboucher81
No, we didn't even know that such a file existed.
We downloaded both the tbb30_104oss_win.zip and the tbb30_104oss_src.tgz files, and there is no such w_tbb_3.0.3.104.exe in these packages.
Where can we find this installation file?
Yves
You can find it on your page on registration center sitehttps://registrationcenter.intel.com
--Vladimir
yboucher81
So this was my mistake.
I thought that for the updates, we had to download them through the commercial-aligned open source site, and simply replace the dlls that we distribute.
We will log to the registration center using our account, and download the updates from there.
Sorry for this, and thank you very much for your help.
Yves.
