What exactly does it mean? TIA
[bash].code ALIGN 4 PUBLIC c __TBB_machine_load8 __TBB_machine_Load8: ; If location is on stack, compiler may have failed to align it correctly, so we do dynamic check. mov ecx,4[esp] test ecx,7 jne load_slow ; Load within a cache line sub esp,12 fild qword ptr [ecx] fistp qword ptr [esp] mov eax,[esp] mov edx,4[esp] add esp,12 ret load_slow: ; Load is misaligned. Use cmpxchg8b. push ebx push edi mov edi,ecx xor eax,eax xor ebx,ebx xor ecx,ecx xor edx,edx lock cmpxchg8b qword ptr [edi] pop edi pop ebx ret EXTRN __TBB_machine_store8_slow:PROC .code ALIGN 4 PUBLIC c __TBB_machine_store8 __TBB_machine_Store8: ; If location is on stack, compiler may have failed to align it correctly, so we do dynamic check. mov ecx,4[esp] test ecx,7 jne __TBB_machine_store8_slow ;; tail call to tbb_misc.cpp fild qword ptr 8[esp] fistp qword ptr [ecx] ret end [/bash]
We distribute the commercial version of TBB as part of a plugin for Internet Explorer and Firefox. But under Windows XP SP3, the MSVCR90.dll is not present by default, and tbb.dll has a dependency on it. So we thought that we could download the source code and build the TBB library ourselves using the configuration that links statically with the C runtime. This works, but the problem is that the resulting dlls (tbb and tbbmalloc) are not signed by Intel Corporation.
Could Intel provide the two versions of the TBB libraries (linked statically or dynamically with the C runtime), and sign the resulting dlls, so that we don't have to distribute the MSVCR90.dll with our plugin?
Thank you
