TBB 3 update 4 terminates on startup
andysem
New Contributor III
The latest release doesn't work with GCC 4.1.0 on Linux, it terminates on firsttask_scheduler_init construction. The problem is that the compiler incorrectly compiles all calls toatomic_do_once, as they written in a few places - it simply doesn't call once initializer. In particular, the crash is caused by not initializingtheNumProcs inAvailableHwConcurrency() on Linux (see tbb_misc_ex.cpp:121) and as a consequence - an attempt to allocate an array of -1 elements at private_server.cpp:318.
I've found 3 places whereatomic_do_once is used improperly. The following simple change fixes the problem:
diff -ur --strip-trailing-cr tbb30_127oss/src/tbb/condition_variable.cpp TBB/src/tbb/condition_variable.cpp
--- tbb30_127oss/src/tbb/condition_variable.cpp	2010-12-08 14:29:02.000000000 +0300
+++ TBB/src/tbb/condition_variable.cpp	2010-12-09 19:36:34.604404300 +0300
@@ -169,7 +169,8 @@
 void internal_initialize_condition_variable( condvar_impl_t& cv )
-    atomic_do_once( init_condvar_module, condvar_api_state );
+    typedef void (*init_condvar_module_t)();
+    atomic_do_once( (init_condvar_module_t)&init_condvar_module, condvar_api_state );
     __TBB_init_condvar( &cv.cv_native );
diff -ur --strip-trailing-cr tbb30_127oss/src/tbb/tbb_misc_ex.cpp TBB/src/tbb/tbb_misc_ex.cpp
--- tbb30_127oss/src/tbb/tbb_misc_ex.cpp	2010-12-08 14:29:02.000000000 +0300
+++ TBB/src/tbb/tbb_misc_ex.cpp	2010-12-10 10:11:07.432904100 +0300
@@ -119,7 +119,8 @@
 int AvailableHwConcurrency() {
-    atomic_do_once( initialize_hardware_concurrency_info, hardware_concurrency_info );
+    typedef void (*initialize_hardware_concurrency_info_t)();
+    atomic_do_once( (initialize_hardware_concurrency_info_t)&initialize_hardware_concurrency_info, hardware_concurrency_info );
     return theNumProcs;
@@ -225,7 +226,8 @@
+    typedef void (*initialize_hardware_concurrency_info_t) ();
     return theProcessorGroups[ProcessorGroupInfo::NumGroups - 1].numProcsRunningTotal;
As a side note, I'll add that without the modification the code does not compile with MSVC 7.1. I know this compiler is not supported anymore, but the change also fixes the problem for this compiler.
Alexey-Kukanov
Andy, thanks for letting us know about the issue and providing the patch.
Would it work with both the compilers if typedefs are omitted and we just explicitly take the address of routines before passing to atomic_do_once?
andysem
New Contributor III
Yes, this seems to work for both compilers.
