TBB 3. update 5.0 question
michaelnikelsky1
I just read the changes of the update 5.0 and happily stumbled upon this:
-Added automatic propagation of master thread FPU settings to TBB worker threads.
What I wonder is: Does this also set the SSE control registers? At the moment I have to do something like
const unsigned int oldState = _mm_getcsr();
_mm_setcsr( oldState | 0x8040);
....do work
_mm_setcsr( oldState);
each time I enter the operator() function of my task since this isnt propagated. Will this be done automatically when I do it in the master thread with the 5.0 update?
Michael
Andrey_Marochko
New Contributor III
Yes, MXCSR is propagated too.
The only caveat is that the snapshot of FPU settings is done at the moment of task scheduler initialization in a master thread (e.g. when task_scheduler_init object is created). Thus if you change them afterwards, the current values will remain unknown to worker threads.
On the other hand if you uninitialize TBB scheduler (destroy task_scheduler_init object), change FPU settings, and then initialize the scheduler again, the new setting will be visible to workers.
michaelnikelsky1
Great news, thanks :)
