TBB Warning: Leaked 1 observer_proxy objects.
wzpstbb
Recently I added my custom task scheduler observer. I got the following warning when debugging:
Does anyone know how to get rid of this warning?
My custom observer is pretty simple:
    class PipelineObserver : public tbb::task_scheduler_observer
        ADrawContext& mDC;
        void operator=(const PipelineObserver&);
        PipelineObserver();
    public:
        PipelineObserver(ADrawContext& dc)
            : mDC(dc)
            observe(true);
        ~PipelineObserver()
            observe(false);
        virtual void on_scheduler_entry(bool  /* is_worker */ )
            if(mDC.HasVirtualDevice())
                mDC.VirtualDevice().AcquireLocalOGLContext();
I used the observer as below:
                    // Pipeline scheduler observer. It observes the worker threads entering the
                    // task arena.
                    PipelineObserver o(dc);
                    // use TBB to execute a parallel while
                    tbb::parallel_while<ApplyIterator> w;
                    ApplyIterator body(*this, iteratorStream, eyePosition, maxCell, &w);
                    w.run(iteratorStream, body);
Thanks!
Kirill_R_Intel
First, the warning is not critical. Most likely the observer_proxy object is just destroyed later.
The warning may appear if TBB task scheduler is destroyed earlier than the observer object. It could happen if you explicitly created task_scheduler_observer in the same scope, though I don't see it in your code. If it is really important to avoid the warning, please attach the full code to reproduce the issue.
Kirill_R_Intel
wzpstbb
Thanks Kirill for the valuable clue. I have fixed this warning.
