TBB and Mingw compiler
Adri_C__S_
Hello everyone,
I have to develop an app under Windows and I want to make it concurrent. My initial idea was to use TBB since I already have some experience with it under Linux. However, searching the  web I have found that it is only fully supported for VS. I have to use the MingW compiler, madatory; so I was wondering if there is any chance of use TBB with Mingw.
Thanks and best regards!.
SergeyKostrov
Valued Contributor II
>>so I was wondering if there is any chance of use TBB with Mingw... Yes and there a couple of reports that it was done. MinGW C/C++ compiler is a Windows version of GCC and TBB library could be built with GCC compiler on many Linux platforms.
Adri_C__S_
Hi Sergey, thanks for your quick reply.
So should I compile like I was doing under Linux, specifying the paths with -L and -I?. I'm a totally noob in Windows development, so this is hard for me to work out. :)
Adri_C__S_
Hi again. I just found this thread today: http://software.intel.com/en-us/forums/topic/291331 I only read a few comments, but it seems that is what I was looking for. Hope this helps anybode else! See you!
Adri_C__S_
Ok, I have compiled those binaries following the comment #5 in the previous link.
SergeyKostrov
>>Hi again. I just found this thread today: http://software.intel.com/en-us/forums/topic/291331 >>I only read a few comments, but it seems that is what I was looking for. I didn't know about that almost 2 year-old thread. Thanks for sharing!
Adri_C__S_
You're welcome!
