TBB and QNX
Dmitry_S_1
Could you explain me, can I use Intel TBB under QNX Neutrino? I can not find any advice or examples on how I could do this. Is it possible? Is it enough to just recompile the source files of Intel TBB in QNX or I should do anything else?
Thank you.
Maksim_D_Intel
Hello
If you want to use TBB on QNX you can firstly try to use regular Linux binaries from our site. In other case you should build library from source code;
List of supported platforms https://github.com/01org/tbb/blob/tbb_2017/doc/Release_Notes.txt
All other platforms are supported by community
