TBB captured exception
morle
yesterday I got this exception while working with a concurrent vector and some std::vectors inside a task:
terminate called after throwing an instance of 'tbb::captured_exception'
what(): vector::_M_range_check
My question is: was the exception raised because I tried to access a position out of bounds in the concurrent vector, or could it be throw by the std::vector too but it was captured by the task scheduler?
SergeyKostrov
Valued Contributor II
Quoting morle
[SergeyK] That is possible. Would you be able to provide a Test-Case?
[SergeyK]Ithink Yes. STL vector exception messages have a'vector::' part. Check
these STLheaders:
stl_vector.h
stl_bvector.h
stl_deque.h
for more technical details.
Sergey
SergeyKostrov
Quoting morle
these STLheaders:
stl_vector.h
stl_bvector.h
stl_deque.h
Sergey
tehpikachu
my sig
Thanks a lot
morle
Thanks!!
It was a STL vector!
