TBB on WinRT (ARM)
Daniil_Osokin
Hi, guys!
I'm looking for instruction for building TBB for WinRT on ARM. I'm know, win8 support is quite experimental now, but may be you have one (or can suggest any related posts)? Please, help me.
RafSchietekat
Valued Contributor III
For ARM, you probably need a GNU compiler, otherwise, if you have a C++11 compiler, "somebody" should look into leveraging that functionality for all the atomics.
Daniil_Osokin
Thanks!
Vladimir_P_1234567890
You can try out  tbb4120130613oss stable release.
--Vladimir
