2456 Discussions
TBB tuple doesn't compile with Xcode 4.4 (clang 4.0)
robmorgan
After upgrading to the latest Xcode 4.4 which has clang 4.0 (based on llvm 3.1), the tbb/compat/tuple header fails to compile.
$ clang --version
Apple clang version 4.0 (tags/Apple/clang-421.0.60) (based on LLVM 3.1svn)
Target: x86_64-apple-darwin11.4.0
Thread model: posix
$ make compiler=clang arch=intel64 test
[cut uninteresting output ...]
clang++ -c -MMD -O2 -DUSE_PTHREAD -m64 -Wall -Wextra -Wshadow -Wcast-qual -Woverloaded-virtual -Wnon-virtual-dtor -I../../src -I../../src/rml/include -I../../include -I. ../../src/test/test_eh_flow_graph.cpp
In file included from ../../src/test/test_eh_flow_graph.cpp:32:
In file included from ../../include/tbb/flow_graph.h:45:
../../include/tbb/compat/tuple:496:67: error: expected expression
get(tuple& t) { return t.get(); }
../../include/tbb/compat/tuple:500:73: error: expected expression
get(const tuple& t) { return t.get(); }
2 errors generated.
make[1]: *** [test_eh_flow_graph.o] Error 1
make: [test] Error 2 (ignored)
Apparently the compiler has a problem with the call to the tuple::get() instance method. It's not clear why; this code compiles with every other compiler I've tried.
I was able to work around the problem by replacing the call to tuple::get() with a call to internal::get_helper::get() (which is how tuple::get() is itself implemented). If anyone can come up with a cleaner workaround I'd be happy to hear it.
Here's the patch:
diff --git a/tbb40_20120613oss/include/tbb/compat/tuple b/tbb40_20120613oss/include/tbb/compat/tuple
index 0c8721c..120b55f 100644
--- a/tbb40_20120613oss/include/tbb/compat/tuple
+++ b/tbb40_20120613oss/include/tbb/compat/tuple
@@ -493,11 +493,11 @@ struct tuple_element {
template
inline static typename tuple_element >::type&
- get(tuple& t) { return t.get(); }
+ get(tuple& t) { return internal::get_helper::get(t); }
template
inline static typename tuple_element >::type const&
- get(const tuple& t) { return t.get(); }
+ get(const tuple& t) { return internal::get_helper::get(t); }
} // interface5
} // tbb
Vladimir_P_1234567890
Thank you for a report, We have the issue on both Lion and Mountain Lion using August command line tools. It looks like a compiler bug.:) Could you submit a patch via http://threadingbuildingblocks.org/contribution_first.php to include it to tbb update in case we do not find a better solution? Thanks, Vladimir
