TPM 2.0
luciano2
Boa noite gostaria de saber se minha placa H310 TEM ESSA BENDITA FUNÇÃO TPM 2.0 PARA PODE ATIVAR NA BIOS E SE TIVER QUAL O BENDITO NOME QUE ESTA NA NA BIOS OU ELA NAO TEM ESSA FUNCAO E NAO PODE SER INSTALADO O WINDOWS 11:
FICO GRATO
DitiD_Intel
Thank you for posting your question in Intel Communities.
We only provide support in English. I have translated your
question.
<good evening I wonder if my board h310 has this blessed function tpm 2.0 to can activate
in bios and if you have what blessed name is in bios or it does not have this function and can not be installed windows 11:>
Does this reflect your question correctly?
Also, could you please confirm if the thread mentioned below is a duplicate of this one?
https://community.intel.com/t5/Intel-oneAPI-Threading-Building/hellp/m-p/1337449#M14985
Thanks & Regards,
Ditipriya.
DitiD_Intel
We have not heard back from you. Could you please provide an update?
Thanks & Regards,
Ditipriya.
DitiD_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks & Regards,
Ditipriya.
