2485 Discussions
The advantage of TBB memory allocator for serial algorithm
yanling_zhisina_com
As can be seen in Tutorial.pdf about TBB, the TBBmemory allocator is designed for parallel programming including scalable_allocator and cache_aligned_allocator. I use TBB memory allocator by the automatic replacement method (set LD_PRELOAD environment variable). What surprises me is that it speedup my serial program by 80%. BTW, my serial program consumes about 2.6G memory.
So can anyone tell me what does TBB memory allocator do to allocat memory so effeciently, compared with the STL memory allocator? Thanks.
Alexey-Kukanov
Most likely, such a significant speedup for the serial program is not only due to faster allocation but also better cache utilization. The allocator does its best to re-allocate recently freed space with the same or "close enough" allocation size.For some applications, especially allocating lots of similar-sized small objects, it can make significant difference; but this can not be guaranteed.
Alexey-Kukanov
yanling_zhisina_com
Got it. Thank you very much.
