2487 Discussions
The proper way to cancel a ConcurrentQueue's Pop condition and his consumer thread
poetinha
Hi folks,
I'm currently migrating to TBB, anyway, I will have the same question... I've attached my sources to explain.
My consumer thread could be waiting on a queue.pop(), since it should be signaled on concurrent queue only... what's the better way to deal with this? I know that a queue will never have a terminate() method :P it's just a workaround for now.
Thanks in advance,
William
concurrent_queue-inl.h
test_consumer.h
nagy
Something like this maybe?
void terminate()
queue.push(nullptr);
void run()
History* hist = queue.pop();
bool terminated = hist == nullptr;
poetinha
pushing a NULL value works only on a blockingqueue, right?
nagy
I dont understand? pop() is blocking in all tbbs concurrent queues, try_pop is non-blocking. And why would it only work on a blockingqueue?
poetinha
My mistake. Thanks a lot. It solved my problem.
Dmitry_Vyukov
Valued Contributor I
Quoting poetinha
Be careful, some use patterns can corrupt memory/crash:
http://software.intel.com/en-us/forums/showthread.php?t=73928&o=d&s=lr
