Does TBB create a single Thread pool when linked with 'n' binaries or a thread pool/binary ?
For example I have multiple instances of the same the .dll in my application and this .dll uses tbb, so will there only be one single thread pool?
Assuring that is the main goal of presenting TBB as a dynamical library.
(Added 2012-12-04) I'm agnostic about these multiple instances (really multiple copies in the working program, or just multiple copies in the file system with only one of them actually linked in, or a simple mistake in the question itself?), because I expect TBB to behave no different than the runtime library (having more than one new/delete pool tends to be a show stopper before you get to worry about more than one thread pool).
>>...I have multiple instances of the same the .dll in my application...
Could you explain how did you do this? For example in a Win32 application...
