Thread Tester For Linux
Nagabhusan_N__Intel_
Please help us how to analyse the result.
-------- Original Message --------
The installation said our os is not compatible.
Still we installed.
Everything went normal.
The output was as below
[aju@localhost ~]$ tcheck_cl /usr/bin/php -c /usr/local/lib/php.ini /home/aju/www/taroby/Fetch-Mails/MailFetcherFromCRON.php 1
Intel Thread Checker 3.1 command line instrumentation driver (27583)
Copyright (c) 2007 Intel Corporation. All rights reserved.
Building project
Instrumenting
2% php ( All Functions ):............................................
2% php ( API Imports ):.........
Running: /usr/bin/php -c /usr/local/lib/php.ini /home/aju/www/taroby/Fetch-Mails/MailFetcherFromCRON.php 1
Verifying new module: bcmath.so
Verifying new module: dbase.so
Verifying new module: dom.so
Verifying new module: gd.so
Verifying new module: imap.so
Verifying new module: json.so
Verifying new module: ldap.so
Verifying new module: mbstring.so
Verifying new module: mcrypt.so
Verifying new module: mysql.so
Verifying new module: mysqli.so
Verifying new module: pdo.so
Verifying new module: pdo_mysql.so
Verifying new module: pdo_sqlite.so
Verifying new module: soap.so
Verifying new module: tidy.so
Verifying new module: xmlreader.so
Verifying new module: xmlwriter.so
Verifying new module: xsl.so
Verifying new module: zip.so
Application finished
_______________________________________________________________________________
|ID|Short Des|Severit|Cou|Contex|Description |1st Acces|2nd Acces|
| |cription |y Name |nt |t[Best| |s[Best] |s[Best] |
|1 |Thread te|Informa|1 |WholeP|Thread termination at |[libselin|[libselin|
| |rmination|tion | |rogram|[libselinux.so.1, 0x3af0]|ux.so.1, |ux.so.1, |
| | | | |1 |- includes stack |0x3af0] |0x3af0] |
| | | | | |allocation of 10 MB and | | |
| | | | | |use of 36.977 KB | | |
We have to check how to analyse the result.
Alexey-Kukanov
Intel Thread Checker noticed a sole thread in your application, and reported that. Obviously if there is just one thread there can't be any threading errors that Thread Checker might help you to capture.
