Trouble Building TBB in windows with CMake
Aiyer__Kartik
I'm trying to use TBB by building from source in my project. I'm doing this on a Windows 10 system and am using the MSVC toolchain that comes with Visual Studio 2019 Community edition. I"m using the standard approach of `git submodule add` and pointing it to TBB github source to get the code. I then followed the following steps in my main CMakeLists.txt.
# TBB
include(tbb/cmake/TBBBuild.cmake)
tbb_build(TBB_ROOT ${PROJECT_SOURCE_DIR}/tbb/ CONFIG_DIR TBB_DIR MAKE_ARGS tbb_cpf=1)
When I run the cmake configuration step I get the following error.
"C:\Program Files\JetBrains\CLion 2019.2\bin\cmake\win\bin\cmake.exe" -DCMAKE_BUILD_TYPE=Debug -G "CodeBlocks - NMake Makefiles" C:\Users\kartik\Projects\cv\hello_cv
-- The C compiler identification is MSVC 19.24.28316.0
-- The CXX compiler identification is MSVC 19.24.28316.0
-- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.24.28314/bin/Hostx86/x86/cl.exe
-- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.24.28314/bin/Hostx86/x86/cl.exe -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.24.28314/bin/Hostx86/x86/cl.exe
-- Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.24.28314/bin/Hostx86/x86/cl.exe -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Intel TBB can not be built: required make-tool (gmake) was not found
TBB Dir = TBB_DIR-NOTFOUND
Is the gmake referred to here GNU Make ? If so why is there a dependency on GNU Make when I'm using the MSVC toolchain? In this case I'm using my IDE (CLion which generates NMake files for windows by default) however I can reproduce the problem running cmake in a power shell terminal.
PS C:\Users\kartik\Projects\cv\hello_cv\build-out> cmake -DCMAKE_BUILD_TYPE=Debug -G "Visual Studio 16 2019" ..
-- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.24.28314/bin/Hostx64/x64/cl.exe
-- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.24.28314/bin/Hostx64/x64/cl.exe -- works
-- Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.24.28314/bin/Hostx64/x64/cl.exe
-- Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.24.28314/bin/Hostx64/x64/cl.exe -- works
Is there a way I can work around this ? I have a MinGW toolchain which should have the GCC tools, however, when I use that toolchain I get the same error as well. Any help would be appreciated.
Vladimir_P_1234567890
is gnu make tool called gmake in your mingw package? it looks you need gmake available in %PATH% when you run cmake.
Vladimir
James_T_Intel
I'm closing this thread due to no activity.
