2456 Discussions
UNICODE / MBCS Character Sets support in TBB library for Windows platforms
SergeyKostrov
Valued Contributor II
I'd like to understand why UNICODE / MBCS Character Sets are not supported in TBB library for Windows platforms?
Since these two Character Sets are not supported in TBB it creates some problems on projects which already
support UNICODE / MBCS Character Sets.
Sergey
Vladimir_P_1234567890
hello Sergey,
do you have a particular test case where unicode is not supported in tbb?
thanks,
Vladimir
SergeyKostrov
Hi Vladimir,
Quoting Vladimir Polin (Intel)
hello Sergey,
thanks,
Vladimir
Something goes wrong when C++ operators 'new' or 'delete' are redefined and UNICODE is used. Several libraries,
like STL, TBB and MFC, and my codes are defining its own versions of these C++ operators. I'll try to create a test-case
but it is not simple.
Sergey
Dave_Harris
I'm using Unicode, MFC and TBB together with no problems. I imagine most apps using TBB on Windows also use Unicode.
