2481 Discussions
Ubuntu 14.04 TBB Intel Parallel Studio compilervars.sh issue
RKraw
I have a problem considering adding tbb to system variables. I have succesfully installed Intel Parallel Studio and I wanted to compile the example applications with TBB. Therefore, I launched compilervars.sh script. After the launch, icc and cilk plus worked correctly (I do not change or quit the terminal in which the script was run)- however, when trying to launch tbb application,   when running make in /tbb/examples/GettingStarte/sub_string_finder, the following error occurs:
fatal error: tbb/parallel_for.h: No such file or directory
running source tbbvars.sh intel64 dit not help either, although no errors occured.
  I tried to install tbb from https://www.threadingbuildingblocks.org/ - the results were exactly the same.
Curious enough, when installing old version of tbb (4.2) via synaptic, everything worked ccorrectly.
Do you know how to fix that issue ?
Best regards
Rafał Krawczyk
RKraw
Another piece of information in this topic- when being a superuser (su command) everything works fine- after running the compilervars.sh makefile runs correctly. However, is there a method to run a makefile without superuser privilleges ?
Best regards
Vladimir_P_1234567890
hello Rafal,
Do you run compilervars or source compilervars? they need to be sourced.
--Vladimir
RKraw
I source the compilevars, so this is not the case.
Best regards
