I'm trying to build a custome tbb::task_scheduler_observer for thread affinity, as shown in this example. I have a header as follows
#define TBB_PREVIEW_TASK_ARENA 1 #define TBB_PREVIEW_LOCAL_OBSERVER 1 #include "tbb/task_scheduler_observer.h" #include "tbb/task.h" #include "tbb/task_arena.h" class MyObserver : public tbb::task_scheduler_observer { public: MyObserver( tbb::task_arena &a); void on_scheduler_entry( bool worker ); [...] }
with an implementation
#include "my_observer.hpp" MyObserver::MyObserver( tbb::task_arena& a ) : tbb::task_scheduler_observer( a ) { this->a_ = a; observe( true ); } void MyObserver::on_scheduler_entry( bool worker ) { /// Two helper function that set and get the affinity mask like shown in the example this->setAffinityMask( this->getAffinityMask() ); }
However, when linking the source code I get the following strange linking error
$ g++ -o main main.cpp my_observer.cpp -std=c++11 -ltbb
/tmp/ccx3034u.o: In function `tbb::interface7::task_arena::terminate()`:
my_observer.cpp:(.text._ZN3tbb10interface710task_arena9terminateEv[_ZN3tbb10interface710task_arena9terminateEv]+0x20): undefined reference to `tbb::interface7::internal::task_arena_base::internal_terminate()'
collect2: error: ld returned 1 exit status
make: *** [test] Error 1
I'm running Ubuntu 14.04 LTS with g++ version 4.8.4 and the newest release of tbb.
This is strange, and my guess is that a much older version of TBB present somewhere in the system is being used by linker. The necessary entry point is present in the binaries since version 4.2 Update 1.
This StackOverflow answer http://stackoverflow.com/questions/14735387/linker-option-to-list-libraries-used can be useful to find which libraries are used by the linker.
On a side note, TBB_PREVIEW_TASK_ARENA has no effect since TBB 4.3. You still need to set TBB_PREVIEW_LOCAL_OBSERVER though.
AFIAR current Ubuntu 14.04 distribution constains tbb 4.2. If you have it installed (/usr/lib/libtbb.so.2 or /usr/lib64/libtbb.so.2) it can be picked up by g++ instead of yours. -L option can be used. the note from Release notes
- If an open source version of Intel TBB is installed to a system
folder like /usr/lib64 on Linux OS, examples may fail to link
because sometimes gcc searches for libraries in an unexpected
order. To resolve this, use the -L linker option to specify
the right location of Intel TBB libraries. This issue does not
affect program execution.
