Using MFC and TBB toegether
izuleta
Has anyone used the TBB concurrent containers with threads created using MFC?
-ignacio
robert-reed
Valued Contributor II
Given the stunning response to this thread, I guess the answer is, "no.
TBB concurrent containers don't require the services of the TBB task scheduling code and use their own internal locking, so I can't see a reason why this won't work. If you're still interested, give it a try and let us know what you find out!
