I was wondering if there was any reason why the condition_variable won't accept a unique lock with a recursive mutex. Compiler gives an error when I try to do that:
[cpp]recursive_mutex rec_mutex;
unique_lock ul(rec_mutex);
condition_variable condVar;
condVar.wait(ul); // <-- compile error saying ul needs tbb::mutex and not tbb::recursive_mutex
[/cpp]
Because 'ul' variable is not declared as 'tbb::mutex'.
Sergey
This is a follow up.
>>...I was wondering if there was any reason why the condition_variable won't accept a unique lock with a recursive mutex...
'unique_lock' is a template class and you need to specify a type 'mutex'. Please take a look at a 'condition_variable' source file located at:
..\[ TBBDIR ]\Include\tbb\compat\
ahh it's a template class. Got it. Thank you. But if I don't provide the type for template it defaults to tbb::mutex? That's why in the above code I get the compile error?
The last comment I made probably doesn't make sense. The problem is not the unique lock, the problem is the condition_variable.
I just noticed the website removes the template defintions. So I put them in brackets. Hopefully there's no confusion.
[cpp] tbb::recursive_mutex rmutex;
std::unique_lock(tbb::recursive_mutex) ul1(rmutex);
std::condition_variable condVar;
condVar.wait(ul1); // <-- compile error here[cpp]
But if I make the unique_lock (tbb::mutex) then it compiles fine. I get 2 different error messages on Win and LX. So my question is why the condition_variable only accepts tbb::mutexe and not tbb::recursive_mutex?
Thank you.
That's a good question.
Since you had a compilation error it didn't. About 2 years ago I had a similar issue with a template class. That is, Microsoft C++ compiler allowed to compile the template with, I would say, a "weaker" declaration. However, MinGW C++ compiler did not and it means that MinGW is a very strict compiler when it comes to declarations. I could provide a small example if interested,
>>...That's why in the above code I get the compile error?
Yes.
>>...I just noticed the website removes the template defintions. So I put them in brackets. Hopefully there's no confusion.
It happened again. Honestly, I posted so many messages regarding that problem with arrow-left and arrow-right characters and I don't know what to tell you now.
>>...But if I make the unique_lock (tbb::mutex) then it compiles fine. I get 2 different error messages on Win and LX. So my question is
Let me take a look at a declaration of 'tbb::recursive_mutex' template class.
Here is a summary of my investigation:
1. This is how a 'wait' method is declared in a 'condition_variable' class:
void wait( unique_lock< mutex > & lock );
2. These two classes are declared as follows:
** mutex.h **
class mutex {
public:
//! Construct unacquired mutex.
mutex() {
and
** recursive_mutex.h **
class recursive_mutex {
public:
//! Construct unacquired recursive_mutex.
recursive_mutex() {
and the 'recursive_mutex' class is not based on 'mutex'. That is, something like this:
class recursive_mutex : public mutex {
public:
Since there is no a C++ operator '=' to convert from type 'recursive_mutex' to type 'mutex' a C++ compiler reports some error:
Error C2664: ...cannot convert parameter 1 from 'tbb::recursive_mutex' to 'tbb::mutex &'...
>>condVar.wait(ul);
I verified the code with Microsoft C++ compiler and it did not compile it when left-arrow mutex right-arrow not used:
Compiling...
..\common\prttests.cpp(42814) : error C2955: 'tbb::interface5::unique_lock' : use of class template requires template argument list
..\include\tbb\compat\condition_variable(113) : see declaration of 'tbb::interface5::unique_lock'
..\common\prttests.cpp(42814) : error C2514: 'tbb::interface5::unique_lock' : class has no constructors
..\common\prttests.cpp(42816) : error C2664: 'void tbb::interface5::condition_variable::wait(tbb::interface5::unique_lock &)' : cannot convert parameter 1 from 'tbb::interface5::unique_lock' to 'tbb::interface5::unique_lock &'
with
M=tbb::mutex
ScaLibTestApp - 3 error(s), 0 warning(s)
Here are three small test-cases I tried with Microsoft C++ compiler:
// Test-Case 1
mutex reg_mutex;
unique_lock[ mutex ] ul( reg_mutex );
condVar.wait( ul );
// Test-Case 2
unique_lock[ mutex ] ul( rec_mutex );
condVar.wait( ul );
// Error C2664: 'tbb::interface5::unique_lock::unique_lock(tbb::mutex &)' :
// cannot convert parameter 1 from 'tbb::recursive_mutex' to 'tbb::mutex &'
// Test-Case 3
unique_lock[ recursive_mutex ] ul( &rec_mutex );
condVar.wait( ul );
// Error C2664: 'void tbb::interface5::condition_variable::wait(tbb::interface5::unique_lock &)' :
// cannot convert parameter 1 from 'tbb::interface5::unique_lock' to 'tbb::interface5::unique_lock &'
// with
// M=tbb::mutex
// and
// M=tbb::recursive_mutex
// and
// M=tbb::mutex
It is clear that another method like:
void wait( unique_lock< recursive_mutex > & lock );
is needed in the 'condition_variable' class.
And final answer to your question:
Another method like:
Note that condition_variable, like thread, is intentionally implemented exactly as described by the new C++ standard (which seems to have adopted it from boost, a known incubator for new standard features), so this limitation is not unique to TBB (as you will readily find). The problem at hand is that TBB has not also provided compatibility support for condition_variable_any.
>>...The problem at hand is that TBB has not also provided compatibility support for condition_variable_any.
Thanks for the note! Does it mean that condition_variable_any could work with mutex and recursive_mutex?
Any type with lock() and unlock() will do, so yes.
