Visual Studio 2012
paul3579
I'm trying out the release candidate of Visual Studio 2012. tbb_exception.h does not compile due to use of std::copy_exception(). I'm having a hard time finding any info on this method. Is it really part of the std namespace? Will VS2012 be supported soon?
Paul
klaim
Would switching to a meta-build system (CMake, premake, whatever) help with this? It seem that, past the learning time and the time necessary to write the scripts, there would be a possibility to generate different setups for these files depending on which visual studio the user wants to use.
