I'm on Windows 7 x64, Visual C++ Express 2012 Update 1, Win7.1 SDK platform, C++ 32 bit, debug build, using TBB for VC10:
When running the debug build, Visual Studio shows a number of memory leaks which after analysis were created by the TBB library. My original scenario has been rather complex, but after meticulous refactoring I was able to produce a minimal sample. I have an additional dependence to wxWidgets, an open source framework, which seems to have something to do with the leak (I suspect it's an indirect influence on the dll loading order). For some reason the combination of statically linking both wxWidgets debug dll and TBB dll causes the leak, without wxWidgets everything is fine.
On my machine I am able to consitently reproduce the behavior. So please let me know if I can help to debug this issue.
The test program is very short, so I present it here in total:
[cpp]#include <tbb/task_scheduler_init.h>
#include <tbb/parallel_for.h>
class __declspec(dllimport) wxStringBase
public:
wxStringBase() ;//
int gnaz = 0;
int main()
if (gnaz != 0)
new wxStringBase;
tbb::task_scheduler_init scheduler;
tbb::parallel_for(tbb::blocked_range<int>(0, 100, 2),
[=](const tbb::blocked_range<int>& r)
return 0;
}[/cpp]
The sole purpose of the " __declspec" is to trigger static dll linkage to the wxWidgets debug library. Without this dummy class the leak is not reproducible. Also if I remove the "parallel_for" there is no leak.
Additionally I have attached the complete VS 2012 project. To get consistent results I found it is necessary to do a full project rebuild (CTRL+ALT+F7), even after changing a single file only, else, the leak is not always reproducible.
So my question is: Is this a real leak? If not: how can the VS 2012 runtime be "pacified" to not show these messages? I cannot simply ignore the leak detector because it is an essential debugging feature. On the other hand the mere usage of TBB currently renders the leak detector useless by flooding debug messages for "leaks" that are triggered by TBB allocations.
Best, Zenju
Here is the debug log after program exit:
'ScalerTest.exe' (Win32): Loaded 'C:\Users\ZenJu\Desktop\ScalerTest\BUILD\ScalerTest.exe'. Symbols loaded.
'ScalerTest.exe' (Win32): Loaded 'C:\Windows\SysWOW64\ntdll.dll'. Cannot find or open the PDB file.
'ScalerTest.exe' (Win32): Loaded 'C:\Windows\SysWOW64\kernel32.dll'. Cannot find or open the PDB file.
'ScalerTest.exe' (Win32): Loaded 'C:\Windows\SysWOW64\KernelBase.dll'. Cannot find or open the PDB file.
'ScalerTest.exe' (Win32): Loaded 'C:\Program Files\C++\wxWidgets\lib\vc10_x86_debug_dll\wxbase28ud_vc_custom.dll'. Symbols loaded.
'ScalerTest.exe' (Win32): Loaded 'C:\Windows\SysWOW64\user32.dll'. Symbols loaded.
'ScalerTest.exe' (Win32): Loaded 'C:\Windows\SysWOW64\gdi32.dll'. Symbols loaded.
'ScalerTest.exe' (Win32): Loaded 'C:\Windows\SysWOW64\lpk.dll'. Symbols loaded.
'ScalerTest.exe' (Win32): Loaded 'C:\Windows\SysWOW64\usp10.dll'. Symbols loaded.
'ScalerTest.exe' (Win32): Loaded 'C:\Windows\SysWOW64\msvcrt.dll'. Cannot find or open the PDB file.
'ScalerTest.exe' (Win32): Loaded 'C:\Windows\SysWOW64\advapi32.dll'. Symbols loaded.
'ScalerTest.exe' (Win32): Loaded 'C:\Windows\SysWOW64\sechost.dll'. Symbols loaded.
'ScalerTest.exe' (Win32): Loaded 'C:\Windows\SysWOW64\rpcrt4.dll'. Symbols loaded.
'ScalerTest.exe' (Win32): Loaded 'C:\Windows\SysWOW64\sspicli.dll'. Cannot find or open the PDB file.
'ScalerTest.exe' (Win32): Loaded 'C:\Windows\SysWOW64\cryptbase.dll'. Symbols loaded.
'ScalerTest.exe' (Win32): Loaded 'C:\Windows\SysWOW64\shell32.dll'. Cannot find or open the PDB file.
'ScalerTest.exe' (Win32): Loaded 'C:\Windows\SysWOW64\shlwapi.dll'. Symbols loaded.
'ScalerTest.exe' (Win32): Loaded 'C:\Windows\SysWOW64\ole32.dll'. Symbols loaded.
'ScalerTest.exe' (Win32): Loaded 'C:\Windows\SysWOW64\msvcr100d.dll'. Symbols loaded.
'ScalerTest.exe' (Win32): Loaded 'C:\Users\ZenJu\Desktop\ScalerTest\BUILD\tbb_debug.dll'. Symbols loaded.
'ScalerTest.exe' (Win32): Loaded 'C:\Windows\SysWOW64\msvcp100d.dll'. Symbols loaded.
'ScalerTest.exe' (Win32): Loaded 'C:\Windows\SysWOW64\imm32.dll'. Symbols loaded.
'ScalerTest.exe' (Win32): Loaded 'C:\Windows\SysWOW64\msctf.dll'. Symbols loaded.
'ScalerTest.exe' (Win32): Loaded 'C:\Windows\SysWOW64\guard32.dll'. Cannot find or open the PDB file.
'ScalerTest.exe' (Win32): Loaded 'C:\Windows\SysWOW64\version.dll'. Symbols loaded.
'ScalerTest.exe' (Win32): Loaded 'C:\Windows\SysWOW64\fltLib.dll'. Symbols loaded.
The thread 0x1a1c has exited with code 0 (0x0).
The thread 0x19d4 has exited with code 0 (0x0).
The thread 0x504 has exited with code 0 (0x0).
Detected memory leaks!
Dumping objects ->
{309} normal block at 0x00A2DE98, 384 bytes long.
Data: < > CD CD CD CD CD CD CD CD CD CD CD CD CD CD CD CD
{308} normal block at 0x00A2DCD8, 384 bytes long.
{307} normal block at 0x00A2DB18, 384 bytes long.
{306} normal block at 0x00A2D958, 384 bytes long.
{305} normal block at 0x00A2D798, 384 bytes long.
{304} normal block at 0x00A2D5D8, 384 bytes long.
{303} normal block at 0x00A2D418, 384 bytes long.
{302} normal block at 0x00A2D248, 404 bytes long.
{301} normal block at 0x00A2D1E8, 36 bytes long.
Data: <T B B W o r k > 54 00 42 00 42 00 20 00 57 00 6F 00 72 00 6B 00
{300} normal block at 0x00A2D028, 384 bytes long.
{299} normal block at 0x00A2B3E0, 28 bytes long.
Data: < > 00 00 00 00 E8 D1 A2 00 04 05 00 00 00 00 00 00
{298} normal block at 0x00A2CE68, 384 bytes long.
{297} normal block at 0x00A2CCA8, 384 bytes long.
{296} normal block at 0x00A2CAE8, 384 bytes long.
{295} normal block at 0x00A2C928, 384 bytes long.
{294} normal block at 0x00A2C768, 384 bytes long.
{293} normal block at 0x00A2B210, 404 bytes long.
{292} normal block at 0x00A2B1B0, 36 bytes long.
{291} normal block at 0x00A2B158, 28 bytes long.
Data: < > 00 00 00 00 B0 B1 A2 00 1C 1A 00 00 00 00 00 00
{277} normal block at 0x00A2ADD8, 384 bytes long.
{270} normal block at 0x00A2A188, 384 bytes long.
{269} normal block at 0x00A2A140, 8 bytes long.
Data: < > AC 9F A2 00 00 00 00 00
{268} normal block at 0x00A2A0F8, 8 bytes long.
Data: <, > 2C 9F A2 00 00 00 00 00
{267} normal block at 0x00A2A0B0, 8 bytes long.
Data: < > AC 9E A2 00 00 00 00 00
{266} normal block at 0x00A2A068, 8 bytes long.
Data: <, > 2C 9E A2 00 00 00 00 00
{265} normal block at 0x00A29E28, 516 bytes long.
Data: < h > 04 00 00 00 68 A0 A2 00 00 00 00 00 00 00 00 00
{264} normal block at 0x00A29DE0, 8 bytes long.
Data: <L > 4C 9C A2 00 00 00 00 00
{263} normal block at 0x00A29D98, 8 bytes long.
Data: < > CC 9B A2 00 00 00 00 00
{262} normal block at 0x00A29D50, 8 bytes long.
Data: <L > 4C 9B A2 00 00 00 00 00
{261} normal block at 0x00A29D08, 8 bytes long.
Data: < > CC 9A A2 00 00 00 00 00
{260} normal block at 0x00A29AC8, 516 bytes long.
Data: < > 04 00 00 00 08 9D A2 00 00 00 00 00 00 00 00 00
{259} normal block at 0x00A29A80, 8 bytes long.
Data: < > EC 98 A2 00 00 00 00 00
{258} normal block at 0x00A29A38, 8 bytes long.
Data: <l > 6C 98 A2 00 00 00 00 00
{257} normal block at 0x00A299F0, 8 bytes long.
Data: < > EC 97 A2 00 00 00 00 00
{256} normal block at 0x00A299A8, 8 bytes long.
Data: <l > 6C 97 A2 00 00 00 00 00
{255} normal block at 0x00A29768, 516 bytes long.
Data: < > 04 00 00 00 A8 99 A2 00 00 00 00 00 00 00 00 00
{254} normal block at 0x00A28FA8, 1920 bytes long.
{253} normal block at 0x00A28D68, 512 bytes long.
{252} normal block at 0x00A28C80, 168 bytes long.
{251} normal block at 0x00A28B40, 260 bytes long.
Object dump complete.
The program '[5228] ScalerTest.exe' has exited with code 0 (0x0).
When you're debugging can you see in 'Output' window of Visual Studio 2012 a list of unloaded DLLs?This is what puzzles me: I do see unloaded dlls in the output window (the log in the first post is what I'm getting for the test case), but only for dynamically linked dlls (FreeLibrary), but not for statically linked ones. Since it's unlikely Microsoft just forgot to unload latter dlls it seems as if this info is just not shown. I'm on Desktop Win7x64 using the most recent VS2012 Update1. Are you able to reproduce the test case?
You can re-define it again and you won't see any memory leaks in 'Output' window.But then I won't see my own memory leaks neither? The problem is similar to using a messy library which only compiles cleanly on level 1 warning while my own code compiles clean even at level 4. Sure I could reduce warning level to 1 for the complete project, but then I cannot enfore the higher standards towards my own code anymore. However in this case it needs to be clarified if it is a "false leak" first - if it's a bug it must not be hidden, but fixed! I had enough adventures in "undefined behavior land" already.
Here is an incomplete example that demonstrates how I control Microsoft's MLD:This is exactly what happens in my test case. You don't see it, but the wxWidgets library in a static object's constructor of the dll enables the CRT MLD. To be 100% clear, what wxWidgets sets is "_CrtSetDbgFlag(_CRTDBG_LEAK_CHECK_DF )", which strictly speaking is not correct according to MS documentation since it disables the "_CRTDBG_ALLOC_MEM_DF". However the MLD is obviously still working fine.
A loading order of DLLs doesn't influence on memory leaksI am referring to the classic problem when "_CrtDumpMemoryLeaks()" is called before certain destructors ran (assuming they do run latter, otherwise this *is* a leak). Since "_CrtDumpMemoryLeaks" is called by the CRT, there must not be any other dll unloading afterwards, which will execute static object destructors of these dlls. I don't know if this is the problem here, If I knew I wouldn't ask for help.
My opinion in that case is as follows: It won't be fixed.I would find that quite sad. Not fixing reported bugs, not even investigating them, is what gives software development support in general a bad name. On the other hand it gives the "more reactive" kind of support the chance to shine while providing the most trivial of help. You'd be surprised how much positive feedback I get when I fix reported bugs of my users - this is not for being brilliant and fast in fixing (well often I'm fast), but most of the time for fixing bugs at all. Damn we need higher standards in software quality. Sorry for the OT rant :)
Many years ago I detected a memory leaks in MFC library and it is not fixed even if I reported to Microsoft. A short response from a guy blamed me for not using MFC in a right way. Of course, who else could be blaimed for this?He probably is paid no matter if he helps you or not. However in latter case he'll have much less trouble. That's a general problem of how to get employees to take responsibility for a product... But let's not bash on MS: I sent bug reports to certain MS employees directly per email and they instantly analyzed and included the fixes in their next release. Often it comes down to who you are asking for support - asking the right people makes a world of difference compared to "official" bug trackers.
When I'm investigating what is wrong with some codes I try to create as cleaner as possible test-case.I have already tested all variations. If I make the test case any more simpler I cannot reproduce the memory leak anymore. *Anyway the question is who is going to solve this?* It cannot be me, since I have no commit rights into TBB. Additionally I do not have deeper knowledge of TBB internals, so it doesn't make sense for me to spend further time on this. Usually an *Intel developer* would take over at this point and analyze what is currently a *trivial* test case - all that's needed to be done is to download the zip file and double-click on the sln file, then press F7. I don't see how I could provide this in an even simpler format for "support" to consume. But I have to admit that I am not a paying Intel customer. So it seems I am just getting the support I have payed for. Fine, but why pretend there is a free bug report forum when problems are ignored? Better take a stand and close it down instead of wasting "invested" developer's time!
That is simply NOT possible. Period.Nonsense, of course it's "possible".
need to ISOLATE COMPLETELY test casesThere is no reason to change the test case in any way. It is reproducing the symptoms in its current form *and* it is minimal.
There are NO any memory leaks for the clean Test-CaseThis is irrelevant since it's a *different* test case.
