Warning during runtime of dpcpp object file
_Santosh_
Hi ,
When Iam running an object file of a  .dp.cpp file, Iam getting the below warning:
$ dpcpp test39.dp.cpp
$./a.out
TBB Warning: The number of workers is currently limited to 23. The request for 31 workers is ignored. Further requests for more workers will be silently ignored until the limit changes.
Max error: 0
May I know , what leads to this warning? and how to get rid of this warning? And what is this warning about?
Please find the code attached!!
AbhishekD_Intel
We are not getting this type of warning as you are getting.
As your warnings are more related to TBB we are moving this issue to the TBB forum, so that the TBB developer can help you with that.
Warm Regards,
Abhishek
Mark_L_Intel
DPCPP/SYCL on CPU executes TBB underneath – and it looks like the machine has 24 cores (23 + master thread).  Somehow, DPCPP requested more cores. I cannot reproduce this issue internally.
