Why do function nodes require a copyable body?
Florian_J_
I tried to create a tbb::flow::function_node on a move-only type, e.g.
#include <tbb/flow_graph.h>
class MyType {
 public:
  MyType() = default;
  MyType(const MyType&) = delete;
  MyType& operator=(const MyType&) = delete;
  MyType(MyType&&) = default;
  MyType& operator=(MyType&&) = default;
  ~MyType() = default;
int main() {
  tbb::flow::graph g;
  tbb::flow::function_node<int, int> {
      g, 1, MyType{}
However, this does not work, because function_body_leaf stores a copy of the body. Why is this necessary? Is it possible, to use move-only types with tbb::flow?
Florian
Christophe_H_Intel
Hi, Florian,
There are several features of the body of function_node which disallow move-only bodies.
  • After a graph has executed, one can fetch the current state of the body to examine it.  A move-only body would leave the function_node without a body to execute.
  • copy-construction
  • re-initialization of the node body with a copy made at construction time.
Chris
Christophe_H_Intel
Hi, Florian,
  • copy-construction
Chris
